Home > Message Board > Home Audio > CD Recorders > F1 F1 simple question but don no the...
Author Thread: F1 F1 simple question but don no the answer
Username: Darshak
I want to copy some audio data to CDRW from the computer but the following message occurs .Please help me what am I supposed to do as I am just a beginner in this field
Cannot find a CD recorder
Windows Media Player cannot copy the files because it cannot find a CD recorder. Check the connection between your computer and the CD recorder. The Windows operating system may not recognize the CD recorder. Use the Add Hardware Wizard in Control Panel to install the appropriate driver file, and then try copying the files again.
For more information about the Add Hardware Wizard, see Windows Help and Support.
Error ID = 0xC00D1176, Remedy ID = 0x00000003
Username: Project6
Post Number: 9629
What computer are you using?
What is your OS?
What kind of CD writer is it?
Are you sure the CD-ROM is write capable?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > CD Recorders > F1 F1 simple question but don no the... [ « Previous ] [ Next » ]
