Home > Message Board > Home Audio > Receivers > Archive through October 13, 2006 > Will this receiver work with these subs?
Author Thread: Will this receiver work with these subs?
Username: Martyf6
Post Number: 8
i noticed this ONKYO receiver is a 2 channel 4 ohm receiver and so are my 2 rockford fosgate p2 car subs, im just looking for a cheap way to put these in my home and i was wondering if theyll work with this receiver, i found it cheap at eCost
http://www.epinions.com/pr-Onkyo_TX_8011_Receiver/display_~full_specs
http://www.ecost.com/ecost/shop/detail.asp?DPNo=185910&adcampaign=email,ewb09326
Username: Martyf6
Post Number: 9
i take it back, they probably wont because thats only speaker impedence...
Username: Project6
Post Number: 9394
Just get a pro amp from a music supply store or a dj shop.
If you want it right, you will spend some money. A powered sub designed for the home will cost you almost the same.
Home > Message Board > Home Audio > Receivers > Archive through October 13, 2006 > Will this receiver work with these subs? [ « Previous ] [ Next » ]
