Home > Message Board > Home Audio > Mini Systems > Sony stereo malfunciton
Author Thread: Sony stereo malfunciton
Username: Simikang
Post Number: 19
hi, i have a sony mini hifi macro component system its basicly two speakers and a bass and the main part, the problem is when ever i exceed the volume passed 11 or so it shuts down it to protection mode or somthing the light strats flashing and i gota unplug it and replug it, any body know how i can fix it without sending to a shop?
Username: Project6
Post Number: 8997
What speakers are you using?
Username: Simikang
Post Number: 20
its the regular speaker it came with its 300 wats the mhc models
Username: Project6
Post Number: 9006
Check the wiring and see if you have them crossed. Has this been happening since you purchased the unit or is it something new?
Username: Simikang
Post Number: 21
it happend about three months after i bought it
Username: Project6
Post Number: 9017
What is the warranty on the stereo? That is a defective unit, it should be repaired.
Username: Simikang
Post Number: 22
il have to call up sony tomrow then, thanks
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Mini Systems > Sony stereo malfunciton [ « Previous ] [ Next » ]
