Home > Message Board > Home Audio > Tuners > Satellite Radio
Author Thread: Satellite Radio
Username: Rickc
Does anyone know if the sound quality out of a satellite receiver into an amp is anywhere comparable to a decent tuner?
Relevant Product Info
Username: J_strazz
I suggest getting a Satellite Ready receiver. It has the Satellite tuner built in. You just need the antenna which is sold separately. I've used my My-Fi receiver in my home stereo and it sounded ok...but then I upgraded my home receiver to one with the XM Tuner built in and the sound is soooo much better.
Username: John_a
London
U.K.
Post Number: 4454
Sound Quality of 'Radio Systems' from Best to Worst, according to http://www.digitalradiotech.co.uk/
FM
broadband internet radio
digital satellite
Freeview
digital cable
DAB
AM
The above is a UK site: "Freeview" means digital terrestrial television; "DAB" means Digital Audio Broadcasting. Currently, in the UK, DAB means broadcast, low-bandwidth MP3.
Username: Rickc
Thanks for your replies. I am surprised. I was under the impression that digital satellite had much larger bandwidth than FM therefore a better sound quality. I guess for my purposes hooking up the satellite receiver to the aux of my amp would still be wise for commercial free background music but not for serious listening.
Username: John_a
London
U.K.
Post Number: 4460
rick,
I had a Nokia satellite receiver and it was very good. It gave digital audio output. After the digital output from the satellite receiver, the sound is probably as good as the Digital-to-Analogue Converters (DACs) in the amp or receiver. DACs in satellite recievers are usually not so good, so if you choose the analogue output from that, the sound may not as good.
The best FM, with a good tuner and antenna, will win because it is analogue all the way through. But you may have fewer channels, and more interference; FM bands are getting crowded with radio stations. Digital satellite audio reception can give sound as good as CD.
Username: Rickc
So it's the DAC's in the satellite receiver that deminish the sound quality, makes sense.
Thanks John
Username: John_a
London
U.K.
Post Number: 4471
That seemed to be true for our Nokia satellite receiver, at least.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Tuners > Satellite Radio [ « Previous ] [ Next » ]
