Thread: Which cheap sub? |
Silver Member Username: James_the_god
Doncaster,
South Yorkshire
England
Post Number: 294 Registered: Jan-05
| Posted on Tuesday, July 18, 2006 - 10:46 am: |
Got some wharfedale diamond 8.1s and Im about to buy a nad c320bee or ca 540a amp. Im pretty sure I'll be missing my current subwoofer as cheap as it is (the diamonds are running off it). I actually like less bass from the diamonds because the midrange and highs are more airy. So looking on hifibitz: http://www.hifibitz.co.uk/advsearchresults.asp The two cheapest subwoofer are the pioneer s-w90s and the yamaha yst-sw005. Anyone lean towards any of them? As a second question, does anyone know how to connect an active subwoofer to an integrated amp? Thanks for any help |
Gold Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 1666 Registered: Feb-04
| Posted on Tuesday, July 18, 2006 - 12:52 pm: |
Why do you want to combine such a cheap sub to a system of higher quality? Why not a mid-Hi sub from a better manufacturer such as Mission. |
Doncaster,
South Yorkshire
England
Post Number: 295 Registered: Jan-05
| Posted on Tuesday, July 18, 2006 - 01:23 pm: |
Money. Cant afford everything as a student. |
Rimouski,
Quebec
Post Number: 1667 Registered: Feb-04
| Posted on Tuesday, July 18, 2006 - 01:38 pm: |
Okay then, I'll submit that you might degrade your music using such a cheap sub and you'd be better off not spending the money. It might make sense for movies hooked-up to a 5.1 receiver, but not really for music hooked-up to a c320bee. |
Doncaster,
South Yorkshire
England
Post Number: 296 Registered: Jan-05
| Posted on Tuesday, July 18, 2006 - 04:15 pm: |
Why would music be degraded? Because the diamonds would be running off the sub? Nah I have no space or need for a home theatre system, I suppose I'll go with the c320bee due to its good strong bass and I actually may not need a subwoofer. However if i went for the ca then how about if i stretched and went for a wharfedale powercube 8a subwoofer? |
Rimouski,
Quebec
Post Number: 1668 Registered: Feb-04
| Posted on Tuesday, July 18, 2006 - 10:07 pm: |
Degraded by the muddy bass of the sub. |
Doncaster,
South Yorkshire
England
Post Number: 297 Registered: Jan-05
| Posted on Wednesday, July 19, 2006 - 10:19 am: |
I suppose Ive never heard a high quality subwoofer so I wouldnt be able to comment on that. However I do know the subwoofer Im currently using is a pile of crap because its boomy and muddy sounding. I actually like the lazy nature of it, so I suppose I'd like a laid back subwoofer.. But none the less its still made of plastic and isnt that accurate. |
Rimouski,
Quebec
Post Number: 1669 Registered: Feb-04
| Posted on Wednesday, July 19, 2006 - 11:47 am: |
Then... get the powercube, or try to audition sometime a bit better still. |
Bronze Member Username: Bvg
Arvada,
CO
Post Number: 45 Registered: May-06
| Posted on Thursday, July 27, 2006 - 12:17 pm: |
While the folks above have a point regarding matching the quality of your sub to the quality of your other system components, try a JBL Northridge E250p. Discontinued, being blown out at near $200, plus shipping. If you want something a little more agile, try the E150p for $50 less. JBL Northridge is not well appreciated on this board, but other owners report being quite pleased. It's not nearly as muddy as some would have you believe, if you set it up properly. Quick spec's: FR = 25-150Hz (+/- 3db), 12" forward firing Polyplas cone, 250w RMS digital amp, ported on the bottom to reduce chuffing, by-passable internal crossover 50-150Hz, phase switch, 2yr warranty. The E150p is the same, just smaller. 10" cone, 150w RMS digital amp, FR 27-150Hz. Good luck. |
Doncaster,
South Yorkshire
England
Post Number: 298 Registered: Jan-05
| Posted on Thursday, July 27, 2006 - 05:54 pm: |
That sounds like a very good option. Quite a bit of power too..since they're discontinued any idea where you'd find the e150p? Checked ebay and nothing on there! |
Arvada,
CO
Post Number: 48 Registered: May-06
| Posted on Thursday, July 27, 2006 - 06:27 pm: |
I tried the usual price grapper, etc. BB has a few store demos left too. |
Silver Member Username: Usa2k4
Post Number: 195 Registered: Dec-04
| Posted on Thursday, July 27, 2006 - 08:38 pm: |
The 150p is NOT a good sub. While the 250p is around $250 shipped, it is a much better one. Or you can try the 12" Dayton at partsexpress.com: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-635 It's being on sale for $138.88 plus about $25 shipping charge. |
Post Number: 196 Registered: Dec-04
| Posted on Thursday, July 27, 2006 - 08:43 pm: |
I forgot to say, in case you want to buy the JBL 150p, check J&R website. I know they have it for $164 shipped: http://www.jr.com/JRProductPage.process?Product=3951966 |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4362 Registered: Mar-05
| Posted on Thursday, July 27, 2006 - 10:57 pm: |
I can confirm that the JBL e150 is a total POS...I used to own one, and kept kicking myself for buying it from day one. Also got greedy when I saw how cheap they were going for on eBay compared to Best Buy. DON'T DO IT!!! The e250 is supposed to be significantly better, but I would only buy it from some place local with a good return policy. |
Doncaster,
South Yorkshire
England
Post Number: 299 Registered: Jan-05
| Posted on Friday, July 28, 2006 - 06:23 am: |
Lots of negative feedback to that jbl i see. No wonder its discontinued. I'll consider that Dayton but remember I do live in the UK so shipping would likely be more! Theres a wharfedale powercube 8a selling for £115 which is my kind of price. Frequency response only goes to 40hz :S. What I dont understand is how the cheaper subwoofers like the ones I mentioned at the beginning of this post actually have a lower frequency response, unless the companies are not mentioning the fact there'd be a signal drop at a certain frequency.. |
Arvada,
CO
Post Number: 49 Registered: May-06
| Posted on Friday, July 28, 2006 - 12:01 pm: |
There's no substitute for listening, especially with regard to a sub. We did not demo the 150p. We did demo the 250p both in the store (not as useful, because the room makes such a huge difference) and at home. It is what it is. I'm not sure I'd recommend it paired with lesser bookshelves or microsats that cannot reach into the mid bass range, but if you restrict it to the low bass range and set it up properly, it is well-behaved and a good value. We're also not asking it to fill a cathedral-sized room. |
Post Number: 197 Registered: Dec-04
| Posted on Friday, July 28, 2006 - 12:45 pm: |
My bad, J., I didn't notice you're in the UK. See if you can get the Athena AS-P4000. This is an excellent but cheap 10" sub. It often goes on sale for about $150 shipped. This is what I'm talking about: http://www.amazon.com/gp/product/B0009WRUZ2/sr=1-4/qid=1154104778/ref=sr_1_4/102 -4373494-6151306?ie=UTF8&s=audio-video |
Arvada,
CO
Post Number: 51 Registered: May-06
| Posted on Friday, July 28, 2006 - 01:33 pm: |
I noticed that the reviews by people using the E250p for HT are extremely positive, those from people using it for music are more mixed. There are a total of 20-some owner reviews that I've found on various review sites. The overwhelming consensus is that the E250p is a great value. I expected it to be much muddier than it is with our setup. It is no better or worse than the other subs we've auditioned in the <$400 range. We've listened to Mirage, Paradigm, Velodyne, an older B+W, and an older Hsu. They each had strengths and weaknesses. YMMV. Good luck. |
Doncaster,
South Yorkshire
England
Post Number: 300 Registered: Jan-05
| Posted on Friday, July 28, 2006 - 03:34 pm: |
Familiar with Paradigm and Mirage, not heard anything at all from B&W although I would love to. The E250p although it may be a fitting sub is out of my budget really. I'll check out that Athena, I've sent an e-mail to the distributor in the UK to ask for prices. It's 100watts rms so that'll be pleeenty! Ive heard many a good thing about Athena too. |
