Home > Message Board > Home Audio > Amps > Archive through October 31, 2003 > Akai Am 93
Author Thread: Akai Am 93
Sorry about starting this as a new thread but the reply window wouldn't open in the AKAI thread.
Information on the Akai Reference Master AM 93
Cost: £549.90 (Retail Sept 1989, Akai Price List)
Details According to Operators Manual (E)
Power Output (1 kHz, 0.7%) 120W (8 Ohms)
150W (6 Ohms)
180W (4 Ohms)
FTC (20Hz to 20kHz) 120W (8 ohms, 0.05%)
150W (6 ohms, 0.07%)
180W (4 Ohms, 0.1%)
Dynamic Power 145W (8 Ohms)
180W (6 Ohms)
250W (4 Ohms)
400W (2 Ohms)
Power Band Width 10Hz to 60 kHz/0.1%
Total Harmonic Distortion 0.008% (1kHz, 8 Ohms)
Phono max, input level 200mV (MM)
Frequency Response 3 Hz to 100 kHz
(+0 db, -3 db)
Tone Control
Treble + - 10 db (10 kHz)
Bass + - 10 db (100 Hz)
Input sensitivity/ impedance
Phono (MM) 2.5mV/ 47 kohms
Phono (MC) 0.25mV/ 470 Ohms
Tuner, etc 150 mV/ 47 kohms
Output level/ impedance
Tape rec out 150 mV/ 1 kohmn
Damping factor 50 (1 kHz)
Residual noise 0.5 mV
S/N
Phono (MM) 85 db
Phono (MC) 67 db
Tuner etc 100 db
Channel Seperation 60 db
Audio Mute -20 db
Required speaker impedance
A or B 4 to 16 Ohms
A and B 8 to 16 Ohms
(D/A Section)
Sampling Frequency 32kHz/44.1kHz/48khz
Digital Filter 8 fs, 18 bit
D/A Convertor 16 Bit, 2 DAC
Digital input level/ impedance
Coaxial 0.5Vp-p/75 ohm
Optical -14 to -23 dBm
Frequency Response 5 Hz to 20 KHz
(+ - 0.3db)
Dynamic Range 95 db
Total Harmonic Distortion 0.003%
Channel Separation 115 db
I will not bother typing in the features (3 pole servo etc)
Note Can anyone tell me the difference between the AM-93 and the AM-95. (I have the latter but it came with the formers operators manuall. It might be just a country distinction)
Hallo,
the difference between AM-93 and AM-95 is the digital section, which was improoved in the AM-95.
The rest is the same.
Christian Klein
Hi,
I have the chance to buy either an Akai AM-67 (cheaper) or an AM-93. I wonder which one is newer and if the 93 is better? As I understand, the 67 was also the top model at that time?? I am especially interested in it because of the built in DAC.
thanks for an answer,
chris
Home > Message Board > Home Audio > Amps > Archive through October 31, 2003 > Akai Am 93 [ « Previous ] [ Next » ]
