Thread: Athena Micra 6 Question |
New member Username: Dain
Post Number: 2 Registered: Jul-06
| Posted on Friday, July 14, 2006 - 05:09 pm: |
Any fellow Canadians out there have the Athena Micra 6 mini HT system? I'm curious as to what the consensus is on its performance.. I picked it up for $300 at futureshop as I'd read many extremely positive reviews on it (especially from a price/value viewpoint). Can someone give me some input/info as to whether they are worth the price, and which receiver best matches them? Also, if I plan on listening more than 50% to music versus home theatre applications (in a small apartment), how much better could I make my system sound by going for bookshelves etc in a comparable price range (maybe up to $500)? Are the micras at all usable for music listening (obviously not super critical listening, but will they really suck?) Thanks! |
Post Number: 8847 Registered: Dec-03
| Posted on Saturday, July 22, 2006 - 09:37 pm: |
Can non-Canadians answer this? |
Post Number: 5 Registered: Jul-06
| Posted on Sunday, July 23, 2006 - 04:24 am: |
Absollutely not! ;) .. Just kidding, go ahead! Any info is good info. I just figured they would be more widespread up north here, that's all. |
Post Number: 8856 Registered: Dec-03
| Posted on Sunday, July 23, 2006 - 05:36 pm: |
I think that the Athena Micra 6's are an excellent set of speakers and do really well with music. They have excellent detail and clarity. And I don't think they suck at all. What receiver will you be using with these? |
Post Number: 6 Registered: Jul-06
| Posted on Monday, July 24, 2006 - 04:58 pm: |
Well I picked up a Pioneer VSX-816k the other day as I had read some recommendations that it would go well with the "bright" sound of the athenas. So far it sounds quite good though the speakers are not broken in yet and I can't really test them properly. One thing I did notice is that there seems to be quite an audible background noise - hiss - from the speakers when the receiver master volume is turned up.. I can hear it in quiet parts of movies especially. Is this normal? Would it help if I replaced the speaker wire they came with with a thicker guage? Other than that I don't think I've quite figured out how to set up the surround sound properly, it's still sounding very localized (ie I can localize the back speakers when specific sounds are channeled there). Lots o things to learn still =D |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4349 Registered: Mar-05
| Posted on Tuesday, July 25, 2006 - 02:41 am: |
speaker hiss is usually the fault of the receiver. If you want dead quiet, zero noise floor, look into the Panasonic sa-xr55/57 digitals. Not sure how well they'd match with the Micras, though if your usage is mostly HT they should be fine. |
Abubala,
Ababala
The Occupation
Post Number: 4350 Registered: Mar-05
| Posted on Tuesday, July 25, 2006 - 02:43 am: |
oh btw, with over 50% music listening I'd definitely just buy a pair of bookshelves for the cost of the Micras and add a cheap sub like the Athena as-p4000. Onix xl-s at $200/pair come to mind. |
Post Number: 7 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 04:13 pm: |
Thanks for the help. What specifically about the receiver would cause the speaker hiss? Is it something I can fix? And why do you suggest the Onix x-ls? As opposed to any number of the other speakers around that price range? |
Post Number: 8 Registered: Jul-06
| Posted on Tuesday, July 25, 2006 - 04:15 pm: |
(I ask because I seem to be able to find glowing reviews of just about all speakers at around 2-300 with the exception on Bose :/) |
