Home > Message Board > Home Audio > CD Players > Archive through January 15, 2007 > Good CD Player?
Author Thread: Good CD Player?
Username: Hannjeff
Halifax, Nova Scotia
Post Number: 148
Im looking for a good cd player, probably highest price ide go is $300 befor tax. But, thats flexible. I only want one disc, cause I havent seen anything high qualit in that price thats multi disc. Ive been looking at brands like NAD. What do you guys favour?
Username: Petergalbraith
Rimouski, Quebec
Post Number: 1642
Does NAD make a CDP for C$300? I didn't think they did anyway. The C521BEE is about C$500.
CDPs don't evolve very fast, so I'd spend the $300 on a used one. I bought a "like-new" Rotel RCD-02 for about that price 6 months ago and I'm satisfied with it.
Edster will tell you to get the Marantz changer for something like US$150, but I've only seen it in Canada for around C$400. Just our luck.
Username: Hannjeff
Post Number: 160
I dont have a clue of they do. Do you think the marantz changer is worth the $400 canadian?
Username: Hannjeff
Post Number: 163
Glubes (local shop) has a Yamaha CDC685 for $300. I know yamie is good quality cause I got there DVDS657 and its absolutly amazing. Are tehre cd players the same quality as there dvd players?
Rimouski, Quebec
Post Number: 1646
Haven't heard it. I still think your best bet in that price range is a $300 to $400 used single-disk CDP, such as a NAD, Rotel or Arcam.
Rimouski, Quebec
Post Number: 1648
Another low price contender for CDPs is Cambridge Audio. The 540C is about C$500, as-is the 540D DVD player (which some say plays CDs nearly as well as the 540C).
Username: My_rantz
Australia
Post Number: 670
I don't know your prices over there, but I very much recommend the NAD C542.
Rimouski, Quebec
Post Number: 1654
That one would be around C$700.
Username: Nuck
Post Number: 3366
Rotel 1072=900cdn.
Rimouski, Quebec
Post Number: 1656
All far above the C$300 budget...
Username: Nuck
Post Number: 3369
pawn shop
Username: Ftalife
Post Number: 116
Most CD players get the same job done. Have to figure if you want brand name or not.
Username: Ftalife
Post Number: 117
Guess extra features can be good though.
Home > Message Board > Home Audio > CD Players > Archive through January 15, 2007 > Good CD Player? [ « Previous ] [ Next » ]
