Thread: Jvc subwoofer |
New member Username: Haydeng
Post Number: 1 Registered: Jul-06
| Posted on Thursday, July 13, 2006 - 12:02 am: |
have a jvc power subwoofer..was hiding cords under carpet when i think i speared it with a carpet nail..i had no power from the sub after that...i replaced the system cable...still nothing..any advice on what to do next...called jvc..opinion was that the sub was probably damaged at the same time..to buy a new one about 100 hundred bucks...should i just go for it? system is a thm45...has been great until now..so much for hiding cables!! |
Bronze Member Username: Serniter
Piscataway,
New Jersey
Post Number: 37 Registered: Mar-06
| Posted on Sunday, July 16, 2006 - 09:53 am: |
I cant imagine spearing a cable can damage the sub unless you powered it on with the damaged cable. You could use this opportunity to upgrade to a better subwoofer. Here are some alternatives: Dayton 10", $124, partsexpress.com Athena AS P4000, $150, amazon.com Onix X-sub, $199, av123.com Mirage S8, $199, vanns.com You might want to use the maximum allowable crossover setting. |
Gold Member Username: Nuck
Post Number: 3425 Registered: Dec-04
| Posted on Sunday, July 16, 2006 - 10:13 am: |
It seems more likely to have damaged the source, possibly a fuse? I have done this myself, Garry. Bank down a tack rail onto a pre-cable. The equipment did live, though. Try the sub on another source? |
