Thread: Dynaudio Audience 52 Setup Help (Hawk/ Rick) |
St. Louis Blues Unregistered guest |
| Posted on Thursday, May 06, 2004 - 01:27 am: |
Rick/ Hawk- Just received my new Audience 52's. Wondering your thoughts on setup settings w/ my Nad T763 / A52's / Polk Subwoofer. Currently have my receiver set to small- w/ x-over settings at 80 Hz. What do you guys think about this setup? Would you change things around? Thanks ahead of time for your help! |
Silver Member Username: Rick_b
New york
Usa
Post Number: 191 Registered: Dec-03
| Posted on Thursday, May 06, 2004 - 06:23 am: |
SLB, Congrats! Are you currently using the system as a 2 channel stereo, or 5.1 (6.1)? 80Hz is a good starting point. How does it sound to you? I am old school and tune by ear. Keep adjusting until the cross-over and gain give you the best blend between sub and speakers. Cheers! |
| Posted on Thursday, May 06, 2004 - 09:38 am: |
Thanks Rick- Setting it up as 2 channel for now- while waiting to pick up a 122C center. Eventually will upgrade the sub/ add 42's as rears. Started out with it set at 80- sounds good so far. Will dial it in with my spl meter this weekend. So far, they sound really good. |
| Posted on Friday, May 07, 2004 - 02:26 am: |
The 52SE Special Edition are already out. Have you guys auditioned this new speakers. Any significant difference with the 52s. |
