Thread: Checking software version on NAD 743 |
Silver Member Username: Dmeister
Post Number: 102 Registered: Dec-03
| Posted on Wednesday, May 05, 2004 - 07:46 pm: |
Does anyone know how to check the software version on the NAD T743 (assuming you can)? |
Bronze Member Username: Newfie
Post Number: 23 Registered: Mar-04
| Posted on Thursday, May 06, 2004 - 09:29 pm: |
Try holding the video and tone defeat buttons together for about 5 seconds. After releasing "AH RESET" should be displayed. Let me know if this works for you. Worked for both my T752 and T763. |
Post Number: 104 Registered: Dec-03
| Posted on Thursday, May 06, 2004 - 10:04 pm: |
There's a Video 6 button on the unit, but not a regular Video button. Pressing this button (Video 6) with the Tone Defeat button for 5 seconds makes the entire display activate, but doesn't show any Reset message...? |
Post Number: 26 Registered: Mar-04
| Posted on Friday, May 07, 2004 - 08:36 pm: |
O.K. Let's see...List the buttons on the lower front face from left to right. I had same thing on the T753. Illumination of all lighting in the display. I was able to figure it out. |
Post Number: 105 Registered: Dec-03
| Posted on Friday, May 07, 2004 - 08:48 pm: |
Apparently, you need to press the "Video 6" and "Tone Control" buttons...
Post Number: 27 Registered: Mar-04
| Posted on Friday, May 07, 2004 - 09:00 pm: |
Hope I helped. Good Luck. |
