Thread: Studio 100 v.2 versus v.3 |
New member Username: Elite
Post Number: 1 Registered: May-04
| Posted on Wednesday, May 05, 2004 - 12:57 pm: |
has anyone heard whether or not the version 3's from paradigm are as good as the version 2's? all the reviews are for the version 2's thanks |
Bronze Member Username: Robertinchico
Post Number: 55 Registered: Apr-04
| Posted on Thursday, May 06, 2004 - 03:29 am: |
Over the years I auditioned the Studio 100's in version 1,2,3. I didn't care for the v1 and v2 versions. To make sure I was not biased against them, I auditioned the new version 3 twice. I went to different shops with at least very good source equipment, then even re-auditioned them with my own cables and interconnects on a full dealer's Denon system. I never warmed up to them and didn't find them competitive in the $2200 range. What is it that people find so appealing about them? I found them generally smeary, a bloated soundstage, bass was muddy but plentiful and I didn't find even sufficient midrange detail or upper highs to have any sparkle, air or presence. I preferred the sound of other Paradigms at half the price. Be sure and check e-bay and audiogon.com for used Studio 100's; should be easy to save some cash if you do decide on them. |
