Thread: HELP PLZ!!! |
Silver Member Username: Talon_es93
Post Number: 252 Registered: Mar-06
| Posted on Saturday, June 24, 2006 - 05:08 pm: |
i wanna make a box for 2 12" CVRS but i don't know much about box building... this is what i had in mind tho and can some one tell me how many hz this port will be...40" wide..14.5" tall...23" deep. made out of 3/4 board...the port will be goin in 22.25" deep..13" tall..10"wide..then it will turn onto the back wall and it will be 13"tallthen idk how many " long or wide.. n idk if i should shart another path way on the next wall...if theres anywere else i can post a pic @ besides here for you guys can look at it will be way easier.. i can't post pic.s here |
Silver Member Username: Daniel_canada
Post Number: 140 Registered: May-06
| Posted on Saturday, June 24, 2006 - 05:39 pm: |
I like a tight box compared to a big box. ... Could you re-type what you have posted. I'm having trouble understanding your post due to the horrid grammar. |
Gold Member Username: Nuck
Post Number: 3181 Registered: Dec-04
| Posted on Saturday, June 24, 2006 - 09:56 pm: |
A trademark of our educational system. Dude, you do not pay by the character here, use all the literacy you may be capable of. Unless you already have.... |
New member Username: I_need_to_know
Post Number: 3 Registered: Jun-06
| Posted on Tuesday, June 27, 2006 - 03:24 pm: |
i have 2 15" spl subs in a box.. but the box has 2 little holes bout the size of a nickle on it... so... whould it hit harder if i made bigger holes????? or what should i do??????????????????????????????? HELP SOME 1 |
Gold Member Username: Touche6784
Post Number: 1040 Registered: Nov-04
| Posted on Tuesday, June 27, 2006 - 03:50 pm: |
all of you are morons. |
