Home > Message Board > Home Audio > Receivers > Archive through October 13, 2006 > Connect receiver to Satellite TV and ...
Author Thread: Connect receiver to Satellite TV and more...
Username: Unregistered
CA
I was able to get the stereo working through the tv...but cant get the (DirectTV) channels working through the receiver?? Trying to hook-up DVD as well. Receiver: Insignia™ 200W 2.0-Ch. Stereo Home Theater Receiver; Model: IS-HC04091.
Help?!
CA
Actually, HD is thrown in as well... and I'm getting no TV at all...or I should say I am getting video but no audio.
CA
Make that DISH network. Sorry, I'm relaying info from my partner over here... thanks again, for any input (no pun intended). :-)
Username: Bvg
Arvada, CO
Post Number: 27
Not much to go on here. Sorry.
By "receiver", do you mean the satellite receiver? By "stereo working through the TV" you mean... I'm not sure? It sounds like you're using the TV speakers for your stereo, which would be unusual to say the least.
Any chance that you have a reasonably saavy and local friend or installer who can help? Sometimes it helps to see the actual setup on site.
Start by simplifying. Hook up exactly one thing at a time. If you're getting video but no audio at the TV, then you have a signal at the satellite receiver, and you are passing it to the TV. That's a start. Check your connections for the audio. Once you've solved that problem, move to the next one.
This gets pretty complicated to describe verbally(lots of typing). There are also many different sorts of cables, which can change how you hook things up.
Username: Nuck
Post Number: 3104
http://www.ce.org/connections_application/
Username: Kano
BC
Post Number: 1038
The three wires for the HD video connection only carry video, you still need to hook up a seperate connection for audio. If the Dish Network box has an orange hole on the back, buy a digital coax cable and connect that to the orange coax in hole on the receiver.
Now you must tell the receiver where the sound is coming from. In options or on the remote, there should be selection for Digital, select the coax #1,2, etc. that you plugged into while the corresponding video is selected.
If you must connect with the red and white holes, usually there is a connection for each video label.
Good luck!
Username: Harjun
arizon700 receiver code.thanks.anybody have this code.
Username: Harjun
hi.could somebody tell how to put favorite channels in fav.i have arizon 700 receiver.thanks.
Username: Nuck
Post Number: 4203
no.
Username: Iffu2006
Dubai, UAE
UAE
Hi guys.. I am a newbie.
I have a PC using 19" LCD monitor. I want to connect my satellite receiver to my PC so that I can use my LCD to use it for watching TV. my receiver has a smartcard to watch pay channels. i need to connect the output of receiver to my PC input. how do i do that. I am having Radeon 9200se (DVI+SVIDEO+VGA) connectors at the back of my card. I have connected my LCD monitor to the 15pin VGA. how do i connect my receiver to this. so that i can watch my satellite channels on my LCD. what cable/convertor do i need. kindly advise..
Home > Message Board > Home Audio > Receivers > Archive through October 13, 2006 > Connect receiver to Satellite TV and ... [ « Previous ] [ Next » ]
