Home > Message Board > Home Audio > Mini Systems > Onkyo CS-210?
Author Thread: Onkyo CS-210?
Username: Skamen
Hi,
I'm looking to buy a shelf system under for $200. I've heard quite a few good things (and a few not so good things) about the Onkyo CS-210. I'm more interested in sound fidelity than head busting bass and extreme volume levels (although I would like a decent amount of volume). It looks like the unit has a sub and tweeter. I've read that it has a subwoofer output port so I can hook up another subwoofer if I want. right?
Is it possible to add more speakers to this unit than the 2 that come with it? Also, would I be able to hook up a turntable to this system through the audio in port? Do you have any suggestions of other shelf systems in this range that have better sound fidelity?
Thanks,
-Scott
Relevant Product Info
Username: Skamen
Also,
I was just looking at a picture of this unit and it looks like the subwoofer and tweeter are in one speaker and the mid-range "normal" speaker is in the other speaker. How well does this work with stereo music? Is the balance all right? Does it sound good?
Thanks again,
-Scott
Username: Skamen
I'm sorry to keep posting. I didn't see a way to edit posts on this forum.
What do you think of the Onkyo MC35TECH? How much better is it than the CS-210? What do you think of this deal:
http://www.accessories4less.com/cgi-bin/category.cgi?item=ONKMC35TECH
Thanks again,
-Scott
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Mini Systems > Onkyo CS-210? [ « Previous ] [ Next » ]
