Thread: Can u make |
Bronze Member Username: Dandandan
Brisbane,
Queensland
Australia
Post Number: 31 Registered: May-06
| Posted on Monday, June 05, 2006 - 05:41 am: |
can u make a home theartre subwoofa sound relli low like car audio subs |
Gold Member Username: Gavincumm
New York
Post Number: 1202 Registered: Feb-05
| Posted on Tuesday, June 06, 2006 - 10:49 am: |
yes, but its called distortion :-) most car audio subs distort on the order of more than 20%. They are designed for SPL, not sound quality, unless you step out of the mass market and do a custom install. quality bass does not call attention to itself, and you are never aware of your subwoofers presence. If your subs are set up properly, it should simply sound like your mains are playing lower, NOT LOUDER, in the bass. car systems are rarely ever set up this way. They usually are in the format of what is known here to the home audio guys as "ghetto blasters." All bass, nothing else. |
Silver Member Username: Reef
Post Number: 275 Registered: Oct-05
| Posted on Tuesday, June 06, 2006 - 10:09 pm: |
That isnt True Gavin, car audio systems can have great sound quality it just depends on wat sub you buy there are subs for SPL and SQ. |
Gold Member Username: Nuck
Post Number: 2885 Registered: Dec-04
| Posted on Thursday, June 08, 2006 - 04:23 pm: |
It is true, Devin. Been tried hundreds of times here alone, the car stuff is made to work in a small confined space, like an Oldsmobile. Unless you live in a car or closet, the car stuff is inappropriate. Unless your listening standards are of the car type anyhow. |
New York
Post Number: 1208 Registered: Feb-05
| Posted on Friday, June 09, 2006 - 04:01 pm: |
Devin... notice I said MOST... not ALL please read thew whole post amd be sure that you understand it before you comment on it :-) |
Post Number: 338 Registered: Oct-05
| Posted on Friday, June 09, 2006 - 07:28 pm: |
Gavin.. (They are designed for SPL, not sound quality), look wat you said right there. you said there ment for spl not sound guality |
New York
Post Number: 1212 Registered: Feb-05
| Posted on Saturday, June 10, 2006 - 04:57 pm: |
ummmm... I said most in the statement directly before that... quote me properly if you are going to quote me... MOST car audio subs distort on the order of more than 20%. THEY (in reference to most) are designed for SPL, not sound quality, unless you step out of the mass market (infinty, audiobahn, polk) and do a custom install (morel, HSU research). I fixed my post so hopefully it will make it easier for you to understand.
Post Number: 2943 Registered: Dec-04
| Posted on Saturday, June 10, 2006 - 07:15 pm: |
And unless you utilise full words, Devin, it is difficult to understand what you are saying. |
