Home > Message Board > Home Audio > Preamps > Sherwood Newcastle P-965 preamp
Author Thread: Sherwood Newcastle P-965 preamp
Username: Fable
Post Number: 44
Does anyone understand the preset 1 and preset 2? The manual is not clear as to what would be the default settings when I turn on the preamp. For example, I use Auto Speaker Setup using the microphone and store the settings in preset 1. Then I manually use the SPL to adjust all channels and store the settings in preset 2. Now, when I turn on the preamp, which setting will it use? the one in preset 1, or the one in preset 2? If I call preset 2, will it remember my selection the next time I turn it on?
Thanks in advance.
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Preamps > Sherwood Newcastle P-965 preamp [ « Previous ] [ Next » ]
