Thread: Hk 340 or denon 2106 |
New member Username: Jortiz71
Post Number: 1 Registered: May-06
| Posted on Tuesday, May 30, 2006 - 02:00 am: |
HEllo, can someone help me deciding between a hk 340 and a denon 2106? which one is the best choice?...Y will be using the reciver with klipsch cinema 8 speakers thanks |
Bronze Member Username: Jethro
Lansing,
Mi
Post Number: 94 Registered: Jan-06
| Posted on Tuesday, May 30, 2006 - 02:24 am: |
all the above are not what i would recommend for the money spent, so just choose what you think sound better.. any opinions you get on this matter aren't going to help you decide for yourself which is the best choice. |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4093 Registered: Mar-05
| Posted on Tuesday, May 30, 2006 - 08:46 am: |
HK would balance out the Klipsch brightness much more readily than the Denon. |
Post Number: 2 Registered: May-06
| Posted on Tuesday, May 30, 2006 - 01:06 pm: |
Thanks jeff, what would be your recomendation then? around that much money what speakers and Recivier would you recommend? |
