Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > Best HT Receiver for ~$500
Author Thread: Best HT Receiver for ~$500
Username: Pbigatel
Ok..so this question has likely been asked, but I have $500 or under spend on a HT receiver. I am yet to buy speakers, but am hooking up system in my new Panny 42" Plasma with HDMI. Looking for opinions on best receiver to buy. Mid-Small room. Any other info needed from me? I am a newbie to this, so jsut looking for idseas and opinions. Thanks.
Username: Pbigatel
ohhh...ideas on speakers for another $500-$800 would be appreciated as well. Or...maybe what I can get Speakers+Receiver for under $1k??? Thanks everyone, much appreciated. This is my first setup over a $250 packaged crap system.
Username: Sackohammers
Post Number: 48
I am a total newb myself.
But from what I've been reading so far, you may want to adjust your receiver to speaker ratio if your budget is $1k.
I love my new Harmon Kardon 635 that I got for around $500. But you may be better off getting a less expensive receiver and allowing yourself more money for speakers. I am sure someone with more expertise will chime in and give more detailed advice.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 4088
here you go Patrick:
Receiver, $350
http://www.accessories4less.com/cgi-bin/item/MARSR5400
5 speakers, $380
http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASB1%2E2&product_name =Audition%20B1%2E2%20Speakers%20-%20Black,%20Pair
http://www.audioadvisor.com/store/productdetail.asp?sku=ATHASC1%2E2&product_name =Audition%20C1%2E2%20Center%20Channel%20-%20Black
subwoofer, $400 shipped
http://www.vanns.com/shop/servlet/item/features/549499051?v_c=Froogle
Username: Suleman36
Maryland
U.S.A.
Post Number: 3847
Patrick, That is a sweet suggestion Ed just gave you. Ed def recommends great stuff for great prices if your on a budget.
Post Number: 49
No doubt, that looks really good. Ed is quite the shopper.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 4095
credit the wife, she has my credit card under lock and key. : P
Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > Best HT Receiver for ~$500 [ « Previous ] [ Next » ]
