Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > NAD T752 hissing, help?
Author Thread: NAD T752 hissing, help?
Username: Slimmer
Post Number: 12
Hello,
My T752 has started hissing. It just sounds like static. The weird thing is that the hissing is louder at certain volumes than others. There are certain ranges that the hissing is not noticeable, then one click later the hissing is quite loud. I don't mean that the louder the volume, the louder the hiss. Certain volumes have more hiss than others, regardless of source or material. Any suggestions?
Thanks
Username: Project6
Post Number: 8204
Bring it back to your dealer and have it serviced.
Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > NAD T752 hissing, help? [ « Previous ] [ Next » ]
