Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > DTS/thx/dolby pro logic
Author Thread: DTS/thx/dolby pro logic
Username: Cerebus
Can someone help me with all this crap? I kind of understand but what would be best? The receiver is capable of all that stuff and more, but what should I use? I have a 6.1 setup, any help will be appreciated
Username: Jethro
Lansing, Mi
Post Number: 93
dts whenever possible
Username: Jan_b_vigne
Dallas, TX
Post Number: 8541
People get as tired reading it as I do typing it. Put each one in a search engine.
Otherwise, THX does not preclude DTS but has nothing to do with DTS. THX is a standard of specifications and is a way of ensuring a level of performance. You cannot choose THX if you haven't bought THX equipment. You have to buy an entire THX system and source material to make THX viable. THX is not required to have a good surround system. DTS and Pro Logic are exclusive of one another. If you are still using Pro Logic for anything (other than regular TV), you need a better system. If you think Pro Logic sounds good, you need a better system.
Username: Chitown
Post Number: 1015
I wouldn't agree that DTS sounds best (if that's what you are saying Jeff). In my experience it seems that it really depends on the source recording. In some instances some of the other DSP choices can work better because of their coding matching to what is sent through the various devices.
Username: Kano
BC
Post Number: 984
If a DTS recording is mastered as well as the equivalent Dolby Digital recording, I would always choose DTS.
I have as Stof preluded to, encountered a few DTS tracks that were remastered from the original Dolby Digital track. Often these will sound no better and sometimes worse.
But if the movie was originally mastered in DTS it is a safe bet it will be the better choice.
I agree with Jan Pro Logic is crap.
Username: Peychaud
Post Number: 25
I'm sorry if this is a stupid question, but I was surprised to discover that I preferred my HK AVR 635's Logic 7 Cinema surround mode to Dolby Digital. I had assumed that Logic 7 was more or less HK's version of Pro Logic, but it was explained to me that Logic 7 differs from Pro Logic in that it processes the true 5.1 Dolby Digital or DTS signal.
Am I losing anything watching movies in Logic 7 as opposed to Dolby Digital? In my experience, the receiver's Dolby Digital mode sounds muffled and compressed in comparison to the clear, wide open sound of Logic 7.
Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > DTS/thx/dolby pro logic [ « Previous ] [ Next » ]
