Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > Simple Receiver Advice?
Author Thread: Simple Receiver Advice?
Username: Bricktop
Hello everyone I am a newbie in HT equipment. I'm looking for a receiver to power two large Jensen floor speakers that are about 10 years old. So, I really just need something for a 2.0 setup. I'm looking for something in the 150-200 dollar range. Would like to set up with tv, dvd, xbox, and computer. I would probably use about 50/50 music/movies with it. I have read some crummy reviews on the sony that fits my descriptions. Any suggestions would be appreciated
Username: Bricktop
Oh yea - I'm not concerned about FM quality, as I will primarily use it with computer/iPod.
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 4017
go to Harman Audio on eBay and bid on a 3480, it's a 120wpc stereo receiver that usually goes for $160-200.
or you could look on eBay for used Twin-Powered HK receivers from the 70s/80s but don't know if it would have enough modern connections for you.
Username: Bricktop
Thanks alot. Any other suggestions?
Home > Message Board > Home Audio > Receivers > Archive through June 01, 2006 > Simple Receiver Advice? [ « Previous ] [ Next » ]
