Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Sanyo tv
Author Thread: Sanyo tv
Username: Bcoleman719
i have a sanyo tv that has developed a humming or buzzing sound, the remote does not work unless you are less than 3 ft from tv. the picture is still good. what might be the problem and is it worth repairing?
Username: Project6
Post Number: 8061
Hello Brenda... you posted your question on the wrong forum. This is Home Audio and Subwoofer.
And no...your TV is not worth repairing.
Username: Unreal_t
United States
Post Number: 12
You might have some sort of interference, or something screwed up in it(the obivous). If it's worth a repair is up to you, whether you think it might screw up again or no, and you can probably buy a new remote. If you are going to buy a new t.v and are concerned with quality get a SONY! SONY=great quality and durability...you won't regret it trust me.
Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Sanyo tv [ « Previous ] [ Next » ]
