Thread: Please help. Which receiver should I get??? |
Bronze Member Username: Aspis
Post Number: 11 Registered: Apr-06
| Posted on Monday, May 15, 2006 - 12:48 pm: |
I just got my Paradigm Cinema 110 CT HT system and I need help on choosing a receiver. I was thinking about the Denon 2807. What do you guys suggest I should get? How does the Marantz sounds with the Paradigm? Thanks |
Gold Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 4002 Registered: Mar-05
| Posted on Monday, May 15, 2006 - 01:12 pm: |
The Marantz would be a very good choice. |
Bronze Member Username: Darth
The woodlands
Post Number: 54 Registered: Aug-05
| Posted on Monday, May 15, 2006 - 01:36 pm: |
no, no, no. Get this one http://www.hometheaterstore.com/store/product.php?productid=1307&cat=0&page=1 |
Post Number: 12 Registered: Apr-06
| Posted on Monday, May 15, 2006 - 11:53 pm: |
What about the Harman Kardon receivers? Are they suited well with the Paradigm speakers? Thanks |
Abubala,
Ababala
The Occupation
Post Number: 4005 Registered: Mar-05
| Posted on Tuesday, May 16, 2006 - 02:10 am: |
Yes, HK should also be a fine choice. |
