Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > New setup - need connect subwoofer ad...
Author Thread: New setup - need connect subwoofer advice.
Username: Radio1_mike
Post Number: 15
Hi.
I have a Klipsch ProMedia 2.1 setup and a new stereo setup (just shipped to me). I'd like to use the sub from the 2.1s with my receiver (HK AVR-135).
The sub is powered. But its only input in a DIN plug that comes from a control box (detachable- on left speaker) that controls speaker power on and sub level. The sub has its own power rocker switch. That DIN plug also receives stereo from 1/8" plug (sound card output) and you hook the speaker up through pin connectors on the sub itself.
Does it sound okay to take that stereo input and use an RCA plug converter to then hook to sub out from receiver (RCA-type)?
Username: Edster922
Abubala, Ababala
The Occupation
Post Number: 3935
I'd think that if you have the HK's crossover turned on, it should be ok.
only one way to find out for sure...
Username: Project6
Post Number: 7837
Chief, get a proper sub. Don't bother rigging those subs. And no, they will not sound okay at all.
Username: Gavincumm
New York
Post Number: 1075
they are crossed over too high.
Username: Edge2305
Houston, Tx
Us
HEED HELP ON CONNECTING MY SUBWOOFER ITS A Bazooka BT8024DVC IT HAS TWO SETS OF TERMINALS(2POSITIVE 2 NEGATIVE) AND I HAVE A 4 CHANNEL AMP HOW DO I HOOK THE AMP TO THE SUB
Username: Project6
Post Number: 7869
Carlos, start your own thread! This is not the CAR AUDIO FORUM, this is Home Audio!
Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > New setup - need connect subwoofer ad... [ « Previous ] [ Next » ]
