Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Magnet damage?
Author Thread: Magnet damage?
Username: Killboy
this might be a bit of a newbie question but i'm buying a subwoofer tomorrow and just need to know if the magnet inside will damage my tv if it's kept too close. it's LCD and i've heard that magnets don't effect LCD tv's but i'd like to know for sure.
also is there any danger in keeping it close to my xbox?
Username: Project6
Post Number: 7730
You shouldn't have any poblems as long as the speakers are magnetically shielded.
Username: Nuck
Post Number: 2366
If it is a car woofer, it will destroy both.
Pooofh!
Username: Jan_b_vigne
Dallas, TX
Post Number: 8372
With an LCD TV you have nothing to worry about - unless you are hanging your kid's art work on the side of the set. Then the speaker magnets will suck those puny little stick on magnet things from the dentist right off the TV. Schulp!!! Very embarrassing, but it won't hurt the TV.
Username: Thx_3417
Post Number: 1432
Well, I have been using a JBL professional cinema sub bass unit, JBL 4645, right next to my old, but she’s still hold “SONY KX-27PS1” without any trouble what’s so ever, and it’s not even magnetically shielded.
However there is a second sub bass unit that does curse a lot a strain pulling on the “elector guns” not a pretty site I would say!
So its just the one sub for me, why use a 12” when you have an 18” professional model taking up the front stage!
Username: Project6
Post Number: 7767
I think Daniel got his answer.
Username: Thx_3417
Post Number: 1434
Berny
Yeah but still playing around with magnets, not something I’d like to try doing, but still I’m interested to find out the results!?
So if you had a small magnet and moved it pass the screen of a, Plasma screen, the image will remain unaltered or damaged by this wow! Like to see that for real, that would impress me!
Username: Killboy
yeah i've set it all up and i'm not getting any distortion.
the box said it was all magnetically sheilded so thanks for the help everyone
Username: Thx_3417
Post Number: 1437
The first sign of any discolouring inn the image remove the loudspeakers away from the monitor, I have this friend, the choice of loudspeakers in his set-up are, B&W, the left and rights our not the issue hear.
The centre channel B&W CC-6 curses strain in the image, strange don’t you think, considering it’s magnetically shielded?!
Username: Gavincumm
New York
Post Number: 1046
sometimes the shielding in the centers isn't strong snough. It isn't as strange as you might think/
Username: Thx_3417
Post Number: 1440
Gavin
Do you know how they test these units out then?
If I where to take a guess, I’d say they try this out on several makes of TV monitors, to see if it curses discolouration, on the TV monitor.
Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Magnet damage? [ « Previous ] [ Next » ]
