Thread: Pioneer vsx-d711 subwoofer hookup |
New member Username: Clancy
Post Number: 1 Registered: Apr-06
| Posted on Saturday, April 29, 2006 - 07:57 am: |
Hi, ive just bought one of these second hand without a manual. Can anyone offer any help on connecting an active subwoofer to this amp, im really struggling with it? thanks in advance |
Gold Member Username: Nuck
Post Number: 2342 Registered: Dec-04
| Posted on Saturday, April 29, 2006 - 08:41 am: |
the manual says there is a pre-amp sub out. two rca's should do it. Google the unit in question. |
Post Number: 2 Registered: Apr-06
| Posted on Sunday, May 14, 2006 - 01:57 am: |
Nuck, thanks for replying. Ive looked through google and downloaded the manual which doesnt provide me as much detail as I need (first time ive played around with recievers ect..) I have tries conectong rca audio cables with one connector for the pre out on the reciever and two on the sub which im guessing go in the input, still to no avail. Any suggestions on what I may need to do? thanks again |
Post Number: 2560 Registered: Dec-04
| Posted on Sunday, May 14, 2006 - 09:27 am: |
Clancy, I bet you have to enable the sub out on the pioneer. Select dvd or digital and check the options to enable the output and level. My H/K drops the sub enable when unplugged, took a while to sort that out. |
