Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Sounds at different ohms
Author Thread: Sounds at different ohms
Username: Johnfiac
Il
Post Number: 34
Would subwoofers sound better at 1ohm ,2ohm,4ohm,8ohm, ect... My subs are each 2000watts rms at 1 ohm and its a major power drain, If i was to bridge 2 amps togethor for each sub and push out the max rms that they could handle at 4ohms each would it sound better, hit as hard? Or would it sound like $hit.... I need to find out what would hit VERY HARD before i go buying more stereo equiptment, i spent about 4000$ on what i got now and im not happy with it.....
Username: Project6
Post Number: 7660
You will be happier once you post in the right forum. They will be able to answer your questions in the CAR AUDIO FORUM...this is HOME AUDIO.
Username: Gravs
Berny ,
My querry is similar to John's . Please advise , when we talk of OHM's as 4 , 6 or 8 what are we referring to and which sounds better for a Home Audio ? If my speakers are with 6 ohms impedance should i buy a sub woofer with 4 ohm or a 8 ohm impedance ?
Username: Kano
BC
Post Number: 960
Ohms is the overall resistance in the circuit presented to the amplifier. Generally this has no bearing on the sound, and matching ohms between the main speakers and the subwoofer is completely pointless.
Home > Message Board > Home Audio > Subwoofers > Archive through July 29, 2006 > Sounds at different ohms [ « Previous ] [ Next » ]
