Thread: Ipod help |
New member Username: Theguy
Post Number: 1 Registered: Apr-06
| Posted on Wednesday, April 12, 2006 - 02:53 am: |
i recently bought a 20 gig ipod from my aunt and when i connect it to my PC (after installing the ipod software) it says "this ipod needs to be reformatted for use on your PC. click on the button below to run the ipod updater that will allow you to reformat or restore your ipod" She put alot of songs on it for me that i like so, is there anyway i can backup the music for FREE so i can reformat it? Microsoft explorer tell mes that it has to be formatted as well when i look in my computer. and itunes wont recognize it and neither will anapod extremer. I believe she used a mac to put all the songs on could that be the problem? any insight would help thanks! |
Gold Member Username: John_a
London U.K.
Post Number: 4112 Registered: Dec-03
| Posted on Wednesday, April 12, 2006 - 05:45 am: |
There is a "Disk Tools" program that repairs iPod disks, too. That is on a Macintosh, and comes with the operating system. I would guess there is something similar on a PC running Windows. Not sure if it works on an iPod. |
Post Number: 7497 Registered: Dec-03
| Posted on Tuesday, April 18, 2006 - 01:44 am: |
No, you need to get back with your aunt and get a master file for the music and put it on a disk. You cannot extract the music from the iPod by using a different computer. If you want to do something like this you need to find a hack for your iPod. Results are not guaranteed and sometimes causes more problems than it solves, so beware. |
