Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Energy S8.3 vs. B&W ASW300
Author Thread: Energy S8.3 vs. B&W ASW300
Username: Twebbz
Ann Arbor, Michigan
Post Number: 377
These two little subs are the same price ($350) and same configuration...forward firing 8 inch driver with a downward firing port. Which is a better bet?
Username: Artk
Albany, Oregon
Post Number: 2946
I'm not sure about the Energy but I've had bad luck the B&W subs. I think you can do better with the Outlaw LFM2 (299.00).
Username: Twebbz
Ann Arbor, Michigan
Post Number: 378
Art...There is a concept that seems elusive to me. I think I want to roll off the the main speaker's bottom end where the sub's upper frequency picks up...at the setting of the sub's crossover control. In other words, I don't want the main speakers to produce the frequencies covered by the sub. I would be using the High Level sub speaker inputs. Tim at Alegria said his TOM sub would work this way, but it SEEMS that other subs don't.
I'm thinking that if the woofers of the mains aren't trying to reproduce those low frequencies then the upper bass/midrange would be clearer
Username: Artk
Albany, Oregon
Post Number: 2948
I use a sub to fill at the point at which my speakers roll off at bottom. I don't artificially roll them off but instead have the sub fill in the 40 hz and below frequencies which my speakers don't produce. I'm not clear whether this is for a HT application or music. Your profile shows 2 channel gear.
Username: Twebbz
Ann Arbor, Michigan
Post Number: 379
Yea, just interested in music. I'd like the sub for the Energy C-3s with the Marantz receiver. The room is small, 10'x 11'. I think an 8" sub would be all I would need.
Username: Gavincumm
New York
Post Number: 876
yes it would...
a good 8 inch like the Onix X-series sub or the HSU research would be perfect in a room that size.
Username: Twebbz
Ann Arbor, Michigan
Post Number: 380
Hmmmmm...That Onix-X looks interesting and I've looked at the HSU too. Any pros and/or cons comparing a front firing woofer to a downward firing woofer?
Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Energy S8.3 vs. B&W ASW300 [ « Previous ] [ Next » ]
