Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Should I Bi-Wire my JBL E-100's???
Author Thread: Should I Bi-Wire my JBL E-100's???
Username: Ekriegs
I just dont understand what Bi-wiring my speakers can do for me. Isn't it supposed to separate the high frequncies from the low frequencies? If so, how does this help me. If I am wrong...please explain why I should do it.
Thanks
Username: Project6
Post Number: 532
yikes!
here, read this and make your own judgement! B)
http://2eyespy.tripod.com/myaudioandhometheaterhomepage/id3.html
there are articles about wiring on the homepage of this very forum.
swampcat
Bi wire is hype! I have a pair of klipsch speakers bi wired to a adcom gfa555ll power amp. You cant hear the difference. Think about it ,their still connected at the amp terminals 20 feet away, the same as the jumpers at speaker terminals. I tried it ,had an extra set of monster cables ,and just left it this way. Use one good set of speaker cables 10-12 gauge.
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through May 13, 2004 > Should I Bi-Wire my JBL E-100's??? [ « Previous ] [ Next » ]
