Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Sony SA-WX700 keeps blowing fuse
Author Thread: Sony SA-WX700 keeps blowing fuse
Username: Finneyb
This is a nice subwoofer and I enjoyed it for about a year, just past the warranty date. Then the sucker blows a fuse, which requires me to remove around 15 screws to get to it. The fuse is a 6.5 amp 125 volt fuse which I have been unable to find.
I send it off for repair and they tell me $200 because a capaciter is blown. I paid $250 for the speaker.
Has anyone had an issue like this and been able to repair themselves? Does anyone know where I can get a 6.5 amp 125 volt fuse?
Thanks
Bruce
Username: Nuck
Parkhill, Ontario
Post Number: 1718
Home Depot, with a new holder to fit.
Solder, solder.
Username: Nuck
Parkhill, Ontario
Post Number: 1719
Was it a glass fuse?
Was it blackened when you looked at it, or just open?
Did it have a little coil inside it?
What are the letters and numbers on it?
Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Sony SA-WX700 keeps blowing fuse [ « Previous ] [ Next » ]
