Home > Message Board > Home Audio > Subwoofers > Archive through August 01, 2004 > Is polk psw202subwoofer correct for m...
Author Thread: Is polk psw202subwoofer correct for my room size and av receiver
Username: Subabu2002
Erode,, Tamil nadu,i...
India
hi all,
i was confused to select the polk psw 202 for my av receiver.(pioneer vsx d 711)
no other sub is not possible for buy because of various circumstances
my dout is,
1.this sub(polk psw202) is 50 watts powered but my receiver is 100watts power,so if i will used this sub then any problem can happen?
2.if possible to use this sub with my receiver ,then it does will produce enough bass for my room?? because it`s power is 50 watts but my room size is 17*17 and 12feet height.
so,50 watts is enough for my room size??
please help to clear the douts,
India
hi,
any body knows yamaha yst-sw 320.. my room size is 17 * 17 . so,does it will produce enough bass to fill up this room. or then.??
shank
i think the 50watts is prolly the RMS wattage, prolly not the peak/dynamic wattage. Polk's site says it has a peak/dynamic wattage of 100watts.
If you check polk's website (http://www.polkaudio.com/home/), they had a subwoofer wizard/configurator, where you could input your room size, and it will tell you how many decibels the subwoofer and produce for that room.
Home > Message Board > Home Audio > Subwoofers > Archive through August 01, 2004 > Is polk psw202subwoofer correct for m... [ « Previous ] [ Next » ]
