Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > No Power to Sub
Author Thread: No Power to Sub
Username: Blatheirons
I just bought an Infinity SW-12. I got home, plugged it in, and got nothing. The red light came on at first, but without sound. Now I got nothing, no lights, sound or...fog. The sub is a replacement, I simply unplugged the old sub, and plugged the new one in in its place. Pioneer Reciever, standard RCA sub-out. The old one still works fine if I swap it back. Is there a fuse that could have blown inside the box?
FYI - The on-off switch is in the on position, and it is plugged into a standard grounded outlet.
Also, I would have just taken the sub back for replacement, but I bought it out of town, to make matters worse, it was the last one, on clearance and I got a great deal on it. so returning it may mean that i'm out of luck.
Any suggestions would be greatly appreciated.
Well, I am sure everyone that replied to my post is on the edge of their seats waiting to see what the status is.
Well, I took the amp off the back,(Infinity makes it as difficult as possible to replace the fuse) the fuse was blown, I replaced it and it just blew immediately after plugging it in...Great! So I'll just have to return it. 600 miles and a couple weeks from now, I should have my money back. Which leads me to my next question...Which I will make another topic for. If I get half the feedback and constructive help on this new post as I did on this one, I should be in good shape.
Thanks,
Billy Blatheirons IV
Username: Jan_b_vigne
Dallas, TX
Post Number: 7776
Gee, Bryan, your patience makes us look forward to helping you with your next question. Sometimes things just go unanswered here, B. Sorry, that's the way the fuse blows.
I understand that. The follow up post was all in fun. My question was a little too broad for most anyone to accuratly answer anyway, I was just hoping for a miracle.
Username: Gavincumm
New York
Post Number: 798
it just takes a little patience...
good luck with your new purchase whatever it may be!
may I suggest HSU research?
www.hsuresearch.com
Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > No Power to Sub [ « Previous ] [ Next » ]
