Thread: Maybe a stupid question |
New member Username: Tongy66086
Post Number: 1 Registered: Mar-06
| Posted on Thursday, March 02, 2006 - 09:05 pm: |
I have only recently begun playing around with burning my own CD's on my pc. I was wonderhing how, or if, I can record the track name, etc. to the CD so it displays on my car CD player. The stereo in the car will display info from the radio stations, and I think I've seen it do that on some of my newer CD's. Is it possible to do this from my computers CD burner? Thanks so much for you help. |
Unregistered guest |
| Posted on Friday, March 03, 2006 - 10:03 am: |
to Bob Woods done some searching and thinks this might help u re: recording tracks and names...try this link http://www.id3.org/intro.html Glad to help...ACEA...Ireland...Slan. |
New member Username: Doorz
Post Number: 3 Registered: Mar-06
| Posted on Sunday, March 12, 2006 - 10:52 am: |
check if the compact disc logo on your car radio has got 'CD TEXT' written on top,(or if CD-Text is mentioned in the instruction manual) if yes, you can use any popular CD burning program (Nero...) to burn your Audio CD's including CD Text. If your car radio is able to playback Mp3's then you have to check that the id3 tag is correctly filled with track title, artist etc |
