Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Infinity subs
Author Thread: Infinity subs
Username: Igorzzzz
Post Number: 13
Can anyone reccomend one of these subs from Infinity:
Beta sw-10 & Beta sw-12.
My current setup:
Fronts: Monitor Audio Bronze b-4
Rears: Monitor Audio Bronze b-2
Center: Monitor audio Bronze center
Receiver: Pioneer VSX-814
Dvd-player: Pioneer dv-575
Tv: Sony KV-32FQ86B
Roomsize: 20 square meter with hardboard floor
No. Look into Hsu and SVS subs first. Or the Mirage S12 if Vanns.com still has them.
Username: Igorzzzz
The Netherlands
Post Number: 14
Availability of the infinity subs is better heer in Holland (Europe).
Therefore anyone any comments on the infinity subs.
Infinity subs suck, but if that's all you have available then I'd assume the more you pay the less it'll suck.
Username: Igorzzzz
The Netherlands
Post Number: 15
What is it that suck about them.
I mean i don't need a sub wich goes under 20hz or something.
Just a good sub for leastening to music and watching movies. I doesn't have to create an earthshake, i just need civilized bass and don't want to pay too much for it!
let's see: they are weak (low output), dirty (lots of distortion) and overrated (don't go as low as their numbers claim).
See if you can find a Wharfedale or Mission sub instead.
Username: Dobyblue
St. Catharines, Ontario
Post Number: 45
If you're going to buy an Infinity sub I would recommend one that has a CMMD woofer instead of a MMD. There less prone to any cracking of the diaphragm.
Infinity do make good bass, but the best one I see currntly that they offer (in terms of my own ears) is the one that's only available with the Modulus 5.1 system.
There's a Velodyne dealer in Holland - maybe you could check out some of their equipment. I think you'll find a better sub than any of Infinity's stand alone subs.
BETER BEELD EN GELUID
Jeroen Boschplantsoen 87
1318 Almere
Holland
Tel: 31 6 46226586
Email: info@beterbeeldengeluid.nl
Home > Message Board > Home Audio > Subwoofers > Archive through April 04, 2006 > Infinity subs [ « Previous ] [ Next » ]
