Thread: Ipod Nano Charging |
Mike_Ipod_Help Unregistered guest |
| Posted on Monday, February 20, 2006 - 07:34 pm: |
Almost always, when I plug my ipod into my computer to charge it, I get the symbol that says it is already charged, and nothing happens. It will stay like that for hours, and actually causes my battery to die. If I work on it for like half an hour, it sometimes finally begins to charge, but the slightest bump and it seems that it stops charging because the cable isn't connected in exactly the right way. Does anybody else have either of these problems (Ipod says it is already charged when it is not; cable needs to be perfectly worked into place in order for it to charge) and what did you do to fix it? Also, any ideas what the problem here could be? Any help would really be appreciated! |
| Posted on Tuesday, February 21, 2006 - 08:07 pm: |
I really need some help this is very frustrating, does anybody have any ideas? |
| Posted on Wednesday, February 22, 2006 - 05:16 pm: |
Nobody has any ideas? |
