Thread: SACD + DVD Audio problem |
mastercheif912003 Unregistered guest |
| Posted on Thursday, February 16, 2006 - 01:49 am: |
Hi, I am looking to buy a DVD player that plays DVD Audio and SACD's. MY problem is that I have a HTIB system that does not have multichannel analong inputs. Am I screwd? Is there anyway to convert mulitichannel RCA to COAX? |
Post Number: 5854 Registered: Dec-03
| Posted on Thursday, February 16, 2006 - 02:12 am: |
There are plenty of DVD audio and SACD players out in the market that has COAX digital, optical and multi channel analog outputs all in the same player. So don't fret. Just look at the capability of the SACD player you are looking to purchase. |
Bronze Member Username: Dobyblue
St. Catharines,
Ontario
Post Number: 37 Registered: Oct-05
| Posted on Thursday, February 16, 2006 - 08:10 am: |
I thought you can only use the multi-channel outputs for the DVD-Audio and SACD discs and the digital coaxial for the DVD-Video/CD discs. Am I wrong here? I have a DV-45a Pioneer DVD-Audio/SACD player and in order to use the advanced resolution audio tracks on the SACDs and DVD-Audio you have to use the analogue multi-channel cables; if you try to use the optical or digital coaxial you get no sound. |
Silver Member Username: My_rantz
Australia
Post Number: 262 Registered: Nov-05
| Posted on Thursday, February 16, 2006 - 11:33 am: |
Steven is correct. Unless the universal player and receiver are connected by a firewire or in the case of Denon, Denon-link V3, SACD and DVD-A will only pass through the analogue connections. |
New member Username: Audioquery
Post Number: 2 Registered: Apr-08
| Posted on Sunday, April 06, 2008 - 11:15 am: |
Hello guys, I have just purchased a Marantz DV7001 Univ DVD Player and connected this to my Yamaha RX-V1800 A/V Receiver via a Van Den Hul optical cable. Since I am more into music than to movies, am I now able to enjoy SACD/DVD-A with this connection? If not, what additional connections do I have to make in order to enjoy SACD/DVD-A? Also, when the new connnections are in place, will the toslink now be useless and has to be disconnected? Pls guide me from where to where in making these connections(Receiver to Player). Likewise, do I need to make necessary adjustments on the player or just leave the default settings? Lastly, Do I need to have a 5.1 speaker set-up to enjoy the high resolution music or my present 2.1 will do? Thank you very much.. |
