Home > Message Board > Home Audio > Amps > Archive through February 14, 2006 > Amp output affected by speaker ohms
Author Thread: Amp output affected by speaker ohms
Username: Gedenham
My transistor amp is rated at 200 watts RMS into 8 ohms.What would the output be into 14 ohms ?
Username: Nuck
Parkhill, Ontario
Post Number: 1222
What make and model of amp, Gary?
The amp is possibly overrated, but no matter, watts are a made up calculation in most cases, like mine.
Any normal amp rated at 200w will drive a 14ohm load with no problems, regardless of make.
Sound quality is up to you, of course.
Username: Nuck
Parkhill, Ontario
Post Number: 1223
Welcome to the forum, BTW.
Username: Gedenham
The amp is a Genz Benz M-200 bass head. Thanks, Gary
Home > Message Board > Home Audio > Amps > Archive through February 14, 2006 > Amp output affected by speaker ohms [ « Previous ] [ Next » ]
