Home > Message Board > Home Audio > Preamps > Pre-pro with digital outputs
Author Thread: Pre-pro with digital outputs
Username: Jhenderson
Moorpark, CA
I am looking for a pre-pro featuring SP/DIF digital outputs instead of D/As for each of the 5.1 or 7.1 outputs. This allows me to use my own D/As and active crossovers to drive each speaker. The only unit I've seen that will accomodate this is the Meridian G68J. I am primarily interested in DSP music modes such as Dolby PLIIx, as this unit will be used in my primary audio rig.
Can you recommend any other pre-pros that support this?
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Audio > Preamps > Pre-pro with digital outputs [ « Previous ] [ Next » ]
