Thread: Miss my M22ti's a bit |
Celeste J. Unregistered guest |
| Posted on Wednesday, February 01, 2006 - 08:25 pm: |
Husband and I decided to sell them 6 months after purchasing. What I miss is their ability to play relatively loud and clean without a lot of bass booming through our apartment. What I don't miss is the too bright high end (ugggh). Can anyone recommend a similar bookshelf speaker that has the ability to play at a decent volume without being too bass heavy and bright? |
Gold Member Username: Nuck
Parkhill,
Ontario
Post Number: 1157 Registered: Dec-04
| Posted on Wednesday, February 01, 2006 - 09:01 pm: |
Psb B25
Silver Member Username: Kano
BC
Post Number: 820 Registered: Oct-04
| Posted on Thursday, February 02, 2006 - 12:50 am: |
Paradigm Mini Monitor |
Silver Member Username: Twebbz
Ann Arbor,
Michigan
Post Number: 340 Registered: Apr-04
| Posted on Thursday, February 02, 2006 - 09:16 am: |
Paradigm Studio 20 |
Silver Member Username: Gavincumm
New York
Post Number: 496 Registered: Feb-05
| Posted on Thursday, February 02, 2006 - 11:28 am: |
I'll second the studio 20's the 20's will provide enough bass that you can get by without a sub for music listening provided you aren't into pipe organ or rap/hip-hop in an apartment setting. |
Ann Arbor,
Michigan
Post Number: 341 Registered: Apr-04
| Posted on Thursday, February 02, 2006 - 04:40 pm: |
If you're auditioning the Paradigm Studio 20s, have them do an A-B comparison set-up with the Paradigm Monitor 5. The Monitor 5 is a larger bookshelf speaker and is a bit more flexible with different types of music but being a part of their down-market line, they are less refined...good sounding nonetheless. |
VicLewis Unregistered guest |
| Posted on Thursday, February 02, 2006 - 10:45 pm: |
The M22ti's are great in a home theater setup, poor for music. Go with the PSB's, Studio 20 sound at almost half the price. |
| Posted on Friday, February 03, 2006 - 07:46 am: |
Found this review on the PSB's. Makes me think that they will be bright also (no?). http://www.psbspeakers.com/review.php?rId=70&pId=&sId=3 |
Gold Member Username: Artk
Albany,
Oregon
Post Number: 2701 Registered: Feb-05
| Posted on Friday, February 03, 2006 - 09:30 am: |
I third the Studio 20. I owned the Monitor 5's and they are a very nice speaker but not in the same league with the Studio 20. http://www.positive-feedback.com/Issue22/paradigm_studio_20v3.htm http://www.soundstage.com/revequip/paradigm_studio20_v3.htm http://ecoustics.audioreview.com/cat/audioreview/speakers/bookshelf-speakers/par adigm-reference/PRD_298867_4290crx.aspx |
Ann Arbor,
Michigan
Post Number: 342 Registered: Apr-04
| Posted on Friday, February 03, 2006 - 12:14 pm: |
Didn't say the Monitor 5s were in the same league. Just said that I think they are better for a wider range of music. My friend has the 20s on 25" stands, powered by a NAD. They are very nice for classical and jazz but get boppy at louder volumes with music that is bassy with a kick drum. Rock music lacks excitement. The Monitor 5s are better without being heavy. Sure, if you want more refinement you go for the Studio 40s but you also pay a price that I find excessive. |
Bronze Member Username: Tommy_jenkins
Tallahasse,
FL
Post Number: 11 Registered: Dec-05
| Posted on Friday, February 03, 2006 - 01:14 pm: |
These speakers would make you very, very happy: Ascend CBM-170SE or CMT-340SE, ascendacoustics.com |
Silver Member Username: Stu_pitt
Irvington,
New York
Post Number: 893 Registered: May-05
| Posted on Friday, February 03, 2006 - 05:48 pm: |
"Found this review on the PSB's. Makes me think that they will be bright also (no?)." I think very few people would characterize PSB's as bright. If anything, they're slightly warm sounding.
| Posted on Saturday, February 04, 2006 - 12:12 pm: |
Celeste, I agree with you that the M22t's play very loud and clean. Did you ever try mating them with a decent subwoofer? Many people believe that a subwoofer can't be used to bring "balance" to a system, just heavy duty bass. You don't have to dial in a lot of bass, just enough to kind of blend with your bookshelf speakers. By bringing in a little bass, it MAY have blended with the Axioms, and created an overall great sounding system. By the way, the Axiom subs would probably have done the trick, but there are many other brands that would have gone well with the M22ti's. Also, I don't know if anyone at Axiom will admit this, but I don't think that there is any way that those speakers were designed NOT to use with a sub. |
