Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > New House, same speakers
Author Thread: New House, same speakers
Username: Idealconcepts
Sacramento, CALI
Post Number: 17
I might have posted this in the wrong place intially so here goes.
We just moved into our new home, last week and I have the HT set up in the family. The room is fairly open with approximately 30 ft ceilings and is surrounded by an open staircase on two sides, behind the family is the kitchen/nook area. The room is approximately 18 ft wide and about 13 ft deep (actually deeper if you include the kitchen behind it). My set up consist of Rotel RSP 1066 Preamp, Rotel RMB 1075 AMP, Paradigm cc-370 Center, Velodyne CHT 12 Sub, and Paradigm Monitor 9v.4 Fronts and Monitor 9v.3 Rears. I currently have the sub in the little cove the tv is suppose to be but its too small to hold my current tv. The room is tiled with 18x18 in tile and we are planning on placing a large rug in the middle of the room. My question is should I use the spikes that come with the Monitor 9s? Also how does tile affect the sound that is generated from the speakers and the sub?
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 7282
Itttttt makesssssss itttttttt sounddddddd funnyyyyyyyyyy.
Username: Nuck
Parkhill, Ontario
Post Number: 1081
After you try it JR, I see tapestrys in your future.
Lots.
That tile thing will set up sound waves like bbès in a boxcar, I fear.
Sacramento, CALI
Post Number: 21
Ok, so your suggestion is to use the spikes correct? I understand what you mean with the tile making things sound different, so far it hasn't been to bad. Hopefully once the house if fully decorated it will sound closer to normal when the system was on carpet. Thanks.
Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > New House, same speakers [ « Previous ] [ Next » ]
