Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > Axiom or???
Author Thread: Axiom or???
Username: Pko
I am looking for some advice on a home theater system. Money is not an object but want quality state of the art components and the same high end matching speakers. My question is this to all the audioholics who care to give some advice. Denon or Yamaha on the AVR, and what combination of matching speakers. Thanks and I look forward to all responses
Username: Danman
QUEBEC
CANADA
Post Number: 603
I would go with the "or" as I owned AXIOM's before and they were very bright with NAD so imagine using Denon or Yamaha!!!
PSB is a great choice as is Wharfedale's new series of Diamonds and Totem also has a new series for AV at around 2400$ that is really good.
I cannot recommend the Denon or Yamaha as I am not a fan of either....Arcam, Nad and Rotel would be a great choice for amplification. You should try and listen to some gear before choosing since you did mention money was no object, you would be better off taking your time.
Username: Exerciseguy
Brooklyn, NY
Post Number: 389
I love my Monitor Audio Radius set-up, and can strongly recommend it, but if money were not an object, I would strongly consider the Paradigm Reference Series. To a rational fledgling-audiophile like myself, it’s about as good as you get.
Username: Davidpa
Portland, Oregon
US
Post Number: 108
Money no object? aerial acoustics, or revel for the speakers should be looked at, and either bryston or mark levinson for amplification. JMO, as you will get many more recommendations, and if you can afford these it is worth your time to audition along with everything else that will be mentioned. You can do much better than what has been mentioned if your willing to spend$$$$$
Username: Danman
QUEBEC
CANADA
Post Number: 605
Just read your post properly and re-read the "money no factor" part.
I would agree with David however your best bet is to listen as we all have our own tastes! Good luck.
Username: Pko
I am leaning on the Monitor GR-20's with the GR Centre and a pair of the GRfx to round out the surround. With the Denon 4806 AVR. Any/all advice on this match up. Room dimensions are 20 X 20 with vaulted ceiling from 9-15 feet. Thanks PK
Username: Artk
Albany, Oregon
Post Number: 2656
If money is no object I would be looking at a Theta pre/pro and power amp with ProAc Response series speakers. Without money as a limiting factor I would never be looking at a mass market AVR.
Brooklyn, NY
Post Number: 390
Art, how much would those suckers cost?
Brooklyn, NY
Post Number: 391
I must presume that someone who initiates this thread inquiring about Axiom, is not the ProAc league yet, and may, despite the claims that “money is no object”, collapse from "sticker shock" to learn what some “mid-end”, let alone "high-end", speakers can cost today.
Username: Nuck
Parkhill, Ontario
Post Number: 1065
Let's play 'spend PK's money'.
You had best not be as cheap as Ben Stein.
Linn KOMRI speakers as a nice pair, with Bryston 7b sst amps, and a nice Jolida tube cdp, with the Linn uni player as an option.
Brooklyn, NY
Post Number: 392
O.K., if you insist. It not HT equipment, but what the heck...
I want couple of these DIY Fostex full-range monters
And this Univac-Buck Rogers thing-of-beauty
Username: Danman
QUEBEC
CANADA
Post Number: 608
WOW!!!!!!!!!!!!
Username: Chitown
Post Number: 681
Does it come with a Delorean?
Brooklyn, NY
Post Number: 393
It just might.
Username: Nuck
Parkhill, Ontario
Post Number: 1073
ONE POINT TWENTY-ONE JIGAWATTS!!!
Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > Axiom or??? [ « Previous ] [ Next » ]
