Thread: Bi-amping with nad c 320bee |
New member Username: Casa7
Post Number: 8 Registered: Jan-06
| Posted on Sunday, January 22, 2006 - 01:34 pm: |
Is it possible to connect 2 nad's in order to double the power? And how would i do that? Is it bridge and bi-amping the same? |
Silver Member Username: Danman
QUEBEC
CANADA
Post Number: 602 Registered: Apr-04
| Posted on Monday, January 23, 2006 - 08:44 am: |
Well, I have two C272's with a C162 in Bridge mode with each amplifier powering one speaker. You could also use a C372 and C272 together as well without having to buy a pre-amp and save some money. Overall, the answer is yes BUT I needed this power as I have a very large room if you don't need it maybe you should stick to a C372 or C162 and C272. Is there any particular reason you ask? |
Post Number: 10 Registered: Jan-06
| Posted on Monday, January 23, 2006 - 01:24 pm: |
a C372 or C162 and C272 is a lot of money for me. I just think that adding another c 320bbe to mine, i would have more power to drive my speakers, without spending a lot of money I can get it quite cheap (around €220) |
QUEBEC
CANADA
Post Number: 604 Registered: Apr-04
| Posted on Monday, January 23, 2006 - 04:12 pm: |
You would not really have more power as they are not bridgable but the sound may be more dynamic I suppose. My advice is to save or sell to buy the 162 and 272. |
Bronze Member Username: Ellison
Post Number: 35 Registered: Mar-05
| Posted on Monday, February 20, 2006 - 05:35 am: |
Buy a 352 or a 372 instead... |
