Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > Combining A+B for better performance?...
Author Thread: Combining A+B for better performance?
Username: Driftair
Hi,
I have a Harmon Kardon 3500 which supplies 50watts to 8ohm speakers. I plan to have B&W 705 speakers.
The speaker settings are (Headset only, A, B, A+B)
I have read that is safe to connect both A+B to supply power to each speaker respective of left and right, to provide better performance. Also stated was "It is better to leave the amp-reciever set to 8ohms for the speaker setting regardless of the speakers being 8 or 4 ohms.
Please tell me if this will be good or damaging?
Relevant Product Info
Username: Jan_b_vigne
Dallas, TX
Post Number: 7241
It's irrelevant if you are only running one pair of speakers. A and B speaker outputs are wired in parallel to the same amplifier channel. Unless you are simply trying to get as much wire as possible feeding the speakers, you have accomplished nothing of any portent in spending money for the additional cables.
If your quote is from the HK instruction manual, I would believe them. That's why they're called instructions.
Home > Message Board > Home Audio > Speakers > Archive through February 06, 2006 > Combining A+B for better performance?... [ « Previous ] [ Next » ]
