Thread: Cambridge audio 540c/640c |
New member Username: Doc99
Post Number: 1 Registered: Jan-06
| Posted on Monday, January 16, 2006 - 11:37 am: |
Is anyone familiar with the Cambridge audio 540c and 640c. I am considering buying the 540c but am wondering if the upgrade to the 640c is worth the extra money? Any audible difference? I am also concerned that it will play CDRs. It does not mention this on there website? |
Silver Member Username: Sun_king
Leeds,
West Yorkshire
UK
Post Number: 316 Registered: Mar-04
| Posted on Tuesday, January 17, 2006 - 07:50 pm: |
Yes, the 640C plays cdr's - I have checked this. I'd be amazed if any currently produced cdp doesn't. I shouldn't think the move from 540C to 640C will be huge, if you're wanting a genuine upgrade I'd spend more than that. |
| Posted on Wednesday, January 25, 2006 - 06:37 am: |
Take the 640C version 2 you will be Never feel what you pay for...It's incredible CDP...i got one the bad thing i don't like is no CD TEXT..but who care I need SOUND so it perfect... |
Silver Member Username: Ca_convert
Cardiff UK
Post Number: 192 Registered: Jan-05
| Posted on Friday, January 27, 2006 - 06:41 pm: |
The 640C is worth the additional cost, since IMO it has a more stable and better defined soundtage i.e. you can place the instruments in space and time better. It is also slightly more detailed, and a more balanced tonal response. Its also more musical if you want to get a bit flat earth about it. Dont get too blinded by What Hi Fi though...its good but there is still better under £500 despite what you read. The Rotel RCD-02 is similar sonically, only with more conviction and authority and also has HDCD capability too for much the same money. |
