Home > Message Board > Home Audio > CD Players > Archive through May 14, 2006 > Confused
Author Thread: Confused
Username: Blazer
Post Number: 64
Everyone tells me that the best way to connect my NAD C542 cd player to my NAD T763 receiver is via the analog outs in order to take advantage of the C542's better DAC's. I understand this, but I use small speakers and a sub with my receiver's crossover setting at 80. That means the analog signal from the cd player is going through an A/D convesion in the receiver for bass management, then back to analog to be sent to the speakers reaulting in multiple signal conversions. Am I missing something here? Wouldn't it be better to just use the cd player's digital out so that the signal only goes through one convesion? If I had full range front speakers then the analog connection would be best, but with small ones I'm not sure. Thanks for your help!!
nout
I don't understand either, but have you tried it already, use the cd player's digital out so that the signal only goes through one convesion?
What sounds better? That's what counts. (although I would'nt be surprised if you do not hear a difference)
Home > Message Board > Home Audio > CD Players > Archive through May 14, 2006 > Confused [ « Previous ] [ Next » ]
