Home > Message Board > Home Audio > Amps > Archive through February 14, 2006 > Amp Q
Author Thread: Amp Q
ammar
So I bought a INSIGNIA sound system from BestBuy that came with a 2-channel bridgeable amp and 2 12" subwoofers. I have connected everything and everything seems to work fine.
BUT, when the amp turns on only ONE sub works, i switched the terminals to see if somethin was wrong with the other sub. When i did the switch, the non-working sub, worked and the one that did work b4 stopped.
So its obvious that both subs work. I guessing there is something worng with the amp, can anyone confirm that with me.
thankyou!
Username: Jan_b_vigne
Dallas, TX
Post Number: 7172
I'd give Best Buy a call and ask for assistance. Good luck.
Home > Message Board > Home Audio > Amps > Archive through February 14, 2006 > Amp Q [ « Previous ] [ Next » ]
