Thread: NAD C320BEE and active subwoofer - how to connect? |
New member Username: Greg25
Post Number: 1 Registered: Jan-06
| Posted on Friday, January 13, 2006 - 08:37 pm: |
Would anyone know how to connect an active subwoofer to a NAD C320BEE amplifier without subwoofer-RCA outlet? Thanks, Greg |
Bronze Member Username: Nadz
California
Post Number: 28 Registered: Aug-05
| Posted on Saturday, January 14, 2006 - 02:56 am: |
Take out the connection between the pre-out and main in and buy yourself a Y adaptor. Take a set of interconnects and re-connect the pre-out and main in and now your left with a set of pre-outs for the sub.
Post Number: 2 Registered: Jan-06
| Posted on Saturday, January 14, 2006 - 02:44 pm: |
Thanks NADz! That's very helpful! Any quality issues around Y-connectors I should be aware of? |
Silver Member Username: My_rantz
Australia
Post Number: 147 Registered: Nov-05
| Posted on Saturday, January 14, 2006 - 06:15 pm: |
The other method is by speaker line connections on the sub (if your sub has them). Hook up your speaker wires to the speaker input connections on the sub, then wire from the speaker output connections on the sub to your speakers and set the crossover appropriately. |
coonass06 Unregistered guest |
| Posted on Monday, January 16, 2006 - 04:54 pm: |
how do you wire two 4 ohm subwoofers with dual voice coil into a mono amp and make it at 2 ohms |
New member Username: Trancedeejay
Kranj Slovenia
Post Number: 9 Registered: Mar-04
| Posted on Friday, January 27, 2006 - 10:09 am: |
You can also connect crossover from Jamo to the speaker outputs on amp and speakers to crossover. In the middle you have rca sub pre out. Have a nice Day Matt |
Bronze Member Username: Casa7
Post Number: 11 Registered: Jan-06
| Posted on Wednesday, February 08, 2006 - 01:28 pm: |
if i connect a wharfedale SW150 powered to my Nad C 320 BBE through the pre in/out using a Y RCA adaptor, is there any loose in quality? |
