Thread: Archive through October 19, 2005 |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 869 Registered: Mar-05
| Posted on Saturday, August 06, 2005 - 03:17 pm: |
What does that mean? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 4894 Registered: May-04
| Posted on Saturday, August 06, 2005 - 03:54 pm: |
It means I've been having problems with the forum log in. |
Gold Member Username: John_a
London U.K.
Post Number: 3587 Registered: Dec-03
| Posted on Sunday, August 07, 2005 - 05:47 am: |
j.c. - Way back on the is thread, people looked for word to describe the effect of switching to tube amplification. I too am at a loss for words. I think it was Rick himself who suggested "fluid" or "liquid" which I personally thought was a good shot. When you are settled in, if it is simple, go back to solid state for a few days. See how it sounds. There are words people seem to agree on for that.... |
Oakwood,
Ga
Post Number: 870 Registered: Mar-05
| Posted on Sunday, August 07, 2005 - 01:37 pm: |
Unfortunately it is not easy for me to compare unless I hook up the Denon to the Totems. I think that would be unfair though because the NAD (sold to my dad) outshined the Denon considerably. I guess wide open airy would be a good start to describe the tube. It's kinda funny Jan, you asked about the beginning and ending of notes changed with tubes and when I let my inlaws hear it last nigh , the first thing one of them said was how the notes seems to come in and out so much better. I tried to get more out of him so I might be able to share on here , but he couldn't really find more words. I got the jist of it and am starting to understand what you were saying about the emerging and departure of single notes played on instruments. What I find cool is the fact that at very low levels, the tubes still bring full bodied sound to the table. Amazing. |
Oakwood,
Ga
Post Number: 872 Registered: Mar-05
| Posted on Sunday, August 07, 2005 - 01:45 pm: |
Here is a pic if anyone's interested. http://forum.ecoustics.com/bbs/messages/3/153349.jpg |
Oakwood,
Ga
Post Number: 874 Registered: Mar-05
| Posted on Sunday, August 07, 2005 - 02:00 pm: |
And after getting the 4 ohm taps working, it did sound better on the 8's. |
Oakwood,
Ga
Post Number: 878 Registered: Mar-05
| Posted on Sunday, August 07, 2005 - 04:49 pm: |
Sorry I though I put the pic here, here it is:
Oakwood,
Ga
Post Number: 879 Registered: Mar-05
| Posted on Sunday, August 07, 2005 - 05:00 pm: |
What is tube rolling? how do you acomplish it? what are the pros/cons? |
Gold Member Username: Rick_b
New York
Post Number: 1244 Registered: Dec-03
| Posted on Sunday, August 07, 2005 - 08:54 pm: |
Joseph, I have a Jolida. If you want to send me a private email, I will help you cut through the chase. |
Oakwood,
Ga
Post Number: 886 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 11:48 am: |
Do you guys Bias you own amps?? |
Gold Member Username: Kegger
Warren,
MICHIGAN
Post Number: 2577 Registered: Dec-03
| Posted on Monday, August 08, 2005 - 12:01 pm: |
Yes! Most amps have the adjustment and the manual should run you through it. It should be checked say twice a year once you've determined it is stable. Also anytime an output tube is changed it should be rebiased. If you want find out more about tube rolling without us stating it all over again you should take some time and read through this thread, there is a wealth of info! |
Dallas,
TX
Post Number: 4929 Registered: May-04
| Posted on Monday, August 08, 2005 - 01:02 pm: |
The McIntosh amps I use have "fixed bias" and require no adjustment. I check it when I change output tubes but have never had to make an adjustment. Checking requires taking off the bottom plate of the amplifier. To alter the bias setting on a fixed bias amp would require soldering in new bias resistors. You should be aware that all tube amps are not equal in their bias adjustment range. When you change output tubes you should know the "average" bias setting your amp prefers. Looking at tubes to purchase find tubes that have operational characteristics that fall within that range. If you put in an output tube that requires higher bias voltage/current than your amp allows, you'll probably be disappointed in the final sound of the amp. If you run tubes too close to, or beyond, their bias limits, you will drastically change the life span of the tubes. Sometimes "DRASTICALLY"! There is, of course, no need to change bias if you change an input, driver or rectifier tube. http://www.webace.com.au/~electron/tubes/screens.htm http://search.yahoo.com/bin/search?p=fixed%20bias%20McIntosh%20vacuum%20tube%20a mplifiers On most amplifiers with adjustable bias, the operation is simple enough to allow the owner to do what needs to be done on a "maintenance" sort of schedule as Kegger suggests. After warming up the amp to settle the bias, it is usually suggested you check for any drift on a more frequent basis if the amplifier has included a front panel meter and switching for checking individual tubes. This could catch a problem with a bias resistor before it turns into a more expensive repair.
Oakwood,
Ga
Post Number: 887 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 01:39 pm: |
My amp has user bias adjustment on the top of the amp and was wondering if this :https://weberspeakerscom.secure.powweb.com/biasrite/br_page.htm looks like a good idea and also would the VI option be worth investing in? |
Dallas,
TX
Post Number: 4934 Registered: May-04
| Posted on Monday, August 08, 2005 - 02:23 pm: |
I'll let Kegger weigh in also but all you need is a multi purpose multi meter from Radio Shack or a hardware/electronics supply house for $10-15. |
Warren,
MICHIGAN
Post Number: 2578 Registered: Dec-03
| Posted on Monday, August 08, 2005 - 04:12 pm: |
I have to agree with Jan that other stuff looks a little gimicky and your adding something to the amp that you don't know what it might do to the sound or create some unforseen problem. I would just stick to a standard meter for about $30 max. If you want to spend more on a better meter I certainly would not knock anyone doing that. A nice meter that also has the HFE test for both pnp and npn transistors is pretty handy. Look for one that has multiple ohm and voltage settings that go nice and low in the millivolts and resistance so get nice accurate readings on low measurements. Can be a very handy tool for many applications. I personally have 3 meters 1 cheep one and 2 better ones "just in case" and the one I like best is a beckman industrial DM27xL just seems right to me with how it does what it does! |
Oakwood,
Ga
Post Number: 888 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 04:19 pm: |
I was confused guys. I just got the manual faxed to me from Jolida and realize the little connector type thingy at the back of the amp is for the multimeter prongs . I have just completed the initial setting and made it 50.4-50.6 millivolts across the board. Is that sufficient? Manual says anywhere inbetween 45-55mv. |
Warren,
MICHIGAN
Post Number: 2579 Registered: Dec-03
| Posted on Monday, August 08, 2005 - 04:54 pm: |
Sounds about right to me! |
Warren,
MICHIGAN
Post Number: 2580 Registered: Dec-03
| Posted on Monday, August 08, 2005 - 04:56 pm: |
Just curious what were they running at? In other words did you have to make much of an adjustment? |
Oakwood,
Ga
Post Number: 895 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 05:29 pm: |
I started from scratch(went all the way counter clockwise) so i don't know. but it did look a little different (the screw position) after I reset them. |
Dallas,
TX
Post Number: 4937 Registered: May-04
| Posted on Monday, August 08, 2005 - 05:46 pm: |
If the amp is fully broken in, I would allow it to run for several hours to really stabilize the temps in the X-formers and then do some adjustments and listening. Every tube and every circuit have a best point for every system. Just as with the adjustments to be made on a turntable or tweaking speaker placement, adjusting the bias on a tube amp can affect the perceived sound quality. Only you can decide what you hear and what suits your system tastes. Run the tubes down in bias and the amp will run slightly cooler. So will the sound. The amp won't produce quite as much power but it also won't produce as much distortion component. Run the amp hotter with more bias and you push the point where the tubes cross over from = to - waveform just a bit further. The amp runs a little closer to Class A operation at slighly higher wattages. The amp will probably sound somewhat different at the two extremes of bias settings. You can always return it to the mid point if you hear no diffference. On the other hand, running the tubes at the lowest bias voltage possible to get good sound will, somewhat, extend the tubes useful lifespan.
Dallas,
TX
Post Number: 4938 Registered: May-04
| Posted on Monday, August 08, 2005 - 05:47 pm: |
Tube rolloing and bias setting. Welcome to the world of tube neurosis. |
Oakwood,
Ga
Post Number: 896 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 06:13 pm: |
lol it is the ultimate for an obsessive compulsive. |
Warren,
MICHIGAN
Post Number: 2581 Registered: Dec-03
| Posted on Monday, August 08, 2005 - 07:37 pm: |
You talkin about me? LOL! |
Oakwood,
Ga
Post Number: 898 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 08:12 pm: |
Hey Jan, you into espresso?? |
Dallas,
TX
Post Number: 4942 Registered: May-04
| Posted on Monday, August 08, 2005 - 08:52 pm: |
I'm Italian; of course. |
Oakwood,
Ga
Post Number: 900 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 09:43 pm: |
I got a Breville espresso maker a couple of months back and it was a huge jump from the cheapy boiler krups I had. The whole espresso thing seems to compare to the hifi world. You can spend thousands on an espresso machine to get the "perfect" brew and crema. Anyway, I was wondering if you had made the jump to something a little better in quality and did you notice a big diff? |
Atlanta,
GA
Post Number: 903 Registered: Mar-05
| Posted on Monday, August 08, 2005 - 10:03 pm: |
Gonna start rolling my a$s of soon with some Sovtek 12AX7LPS on the pre side to see what happens. Gotta love the endless possiblities with tubes. |
Dallas,
TX
Post Number: 4949 Registered: May-04
| Posted on Monday, August 08, 2005 - 11:07 pm: |
j.c. - Re: espresso Throw away the junk that does the brewing in a machine. Do espresso the way Italians do espresso. Either buy a $1,200 espresso machinatta or a $15 espresso pot. I, of course, use the pot. The machinatta is only for making dozens of cups of cafe at a time. I have several pots that make from one to six cups and a mocha pot also. It is placed on the stove and the water is steamed through the grounds. I gave my nephew one of these pots to replace what he was using from some automatic thing and he loves it. Bialetti Brikka is the best known of the pots but the one I use daily is the la Signora caffettiera. Much better espresso than any espresso maker I've tried. http://www.bialettiusa.com/bialetti/products.html As any Italian will tell you though, it is the coffee that makes the difference once you have the right pot.
Warren,
MICHIGAN
Post Number: 2591 Registered: Dec-03
| Posted on Tuesday, August 09, 2005 - 11:44 am: |
Hey Jan picked up 3 dynaco fm-3 tuners a while back for a good price and finally got around to checking them out well at least the best looking candidate. Brought er up on the variac and she hummed and crackled but we left er running to try and clear out the cobwebs. It did get a little better and got some reception but when moved or bumped still crackled. So I began to check some solder traces and found the usual of someone replacing the can cap with the twists that hold them in. People just don't solder them to the chassis and it's a big source of hum. Then I found a crack in the edge of one board so resoldered the traces. After all that it LIVES! I really like the tone of this unit, very pleasent to listen to. Havn't looked at the other 2 yet, one has an obvious problem of the tuner dial melted and being u shaped so it won't turn. These were suppose to be 2 fm-3's and 1 fm-1 but as it turns out all 3 are fm-3's, allright! |
Dallas,
TX
Post Number: 4963 Registered: May-04
| Posted on Tuesday, August 09, 2005 - 01:08 pm: |
Like most Dyna gear, the FM-3's were decent performers for the money spent. Have you had a tube tuner in your system before? |
Atlanta,
GA
Post Number: 906 Registered: Mar-05
| Posted on Tuesday, August 09, 2005 - 01:09 pm: |
"Gonna start rolling my a$s of soon with some Sovtek 12AX7LPS on the pre side to see what happens. Gotta love the endless possiblities with tubes." Scratch that, gonna try some JJ's instead |
Atlanta,
GA
Post Number: 912 Registered: Mar-05
| Posted on Tuesday, August 09, 2005 - 04:37 pm: |
You guys have to try Eric Bibb on tubes whoa! what a great sound. |
New York
Post Number: 1245 Registered: Dec-03
| Posted on Tuesday, August 09, 2005 - 04:44 pm: |
Ok, easy.....slow down. Don't forget to breathe. |
Warren,
MICHIGAN
Post Number: 2597 Registered: Dec-03
| Posted on Tuesday, August 09, 2005 - 05:13 pm: |
Hope things are goin good there RICK! Jan no I have not had a tube tuner, should be picking up my sherwood today that was sent out to be aligned and gone through by the guy I'm getting it from. I traded a PC for it and the unit was sent to another guy I know who has a buisiness of restoring and aligning tuners and supposably the guy does good work and he really likes this tuner. For what that is worth. I should know more by tommorrow. |
Atlanta,
GA
Post Number: 928 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 07:09 pm: |
Hey guys, does it take some time for the pre amp tubes to break in? Hooked up some JJ TESLA 12ax7wa tubes and while the bottom end is sweet, the mids seem to break up easier than what I had in there (don't know what brand was in there but I think they are Chinese, so then cannot be better). Thoughts? |
Dallas,
TX
Post Number: 5010 Registered: May-04
| Posted on Thursday, August 11, 2005 - 08:22 pm: |
Microphonics! |
Atlanta,
GA
Post Number: 932 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 08:26 pm: |
look it up huh? |
Atlanta,
GA
Post Number: 933 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 08:35 pm: |
will it change , or do I have a bum set. The others didn't break up like this. |
Warren,
MICHIGAN
Post Number: 2608 Registered: Dec-03
| Posted on Thursday, August 11, 2005 - 08:39 pm: |
joseph coulson in my experience the tesla's do have decent bass and mids but the high's aren't that great. If you go back through this thread both jan and I have given our thoughts on tubes. Just a quick feneral rule of thumb from ME is that output tubes don't make as much of a difference as input tubes and that the newer output tubes are pretty good. But for the most part I don't like the new input tubes being made today. So if you want a better sounding tube I suggest you get some older tubes. Telefunken and bugle boy are some of the best all around tubes whjile the mullards are great bass and midrange but all of them are pretty expensive so I usually suggest looking for some RCA's as I feel they are the best bang for the buck and have a pretty good all around tone! |
Atlanta,
GA
Post Number: 936 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 08:56 pm: |
I think I got scared all of a sudden , but I really think it may not have helped that the first cd I threw in was "heavier things" by John Mayer. As nice and clear as this cd is, it is recorded very high and the one song that caught my attn. has a heck of alot going on. I will look for some RCA's though Keg, thanks. It does sound better than the Chinese ones though, I put some Ottmar in and all is well in Jolida land. Do you guys know where I could get some kind of decent wood holder for the tubes I am going to acquire? |
Atlanta,
GA
Post Number: 937 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 09:01 pm: |
Jan I am sorry for bringing up that old post of Tawauns. He just really aggravates me with all of the inconsistency he throws around. It won't happen again. |
Dallas,
TX
Post Number: 5014 Registered: May-04
| Posted on Thursday, August 11, 2005 - 09:24 pm: |
Okey dokey. I don't know what sort of wood holder you're looking for. All tubes are microphonic to some extent. How they react in a ciruit is a function the the tube, the amplifer, the support system and the music. If things are clean(er) with the Ottmar, then the problem has at least something to do with microphonics. Give a quick check for microphonics by placing the volume at a medium low setting with no active input selected (i.e., no music playing). Tap the glass envelope of the tubes with the eraser end of a pencil. The more microphonic tubes will show themself. If this is the problem, you can try to isolate the amplifier farther away from the speakers or switch to less microphonic tubes. Catch 22 is the finer elements of the tube that make it sound good also make it microphonic. Get one, get the other. A quick, cheap simple fix is to get a few tennis or raquet balls and cut them in half. Use these as supports for your amplifier. They're not $300 roller balls, but cost effectiveness scores very high.
Atlanta,
GA
Post Number: 938 Registered: Mar-05
| Posted on Thursday, August 11, 2005 - 10:17 pm: |
Well, it's not the tubes. Didn't really hear anything when tapped. Do tubes go through the usual break in process? maybe I cranked them too soon out of the box? Maybe you guys use something to keep the tubes in for easy access, without having to rebox and stack the original cardboard boxes for storage? |
Dallas,
TX
Post Number: 5022 Registered: May-04
| Posted on Friday, August 12, 2005 - 12:48 am: |
Tubes have to be nice and warm before they sound their best. Since I don't do too much tube rolling any longer, maybe Kegger has an idea for you. I put my unused tubes in their boxes in the closet.
Warren,
MICHIGAN
Post Number: 2613 Registered: Dec-03
| Posted on Friday, August 12, 2005 - 01:53 am: |
Well this may sound weird but I use a couple of fishing tackle boxes. As they have ample storage in the bottom for boxed stuff plus individual trays for tubes I like to test or just rotate. Plus I have an old tube caddie full. |
Atlanta,
GA
Post Number: 939 Registered: Mar-05
| Posted on Friday, August 12, 2005 - 07:41 am: |
perfect |
Dallas,
TX
Post Number: 5032 Registered: May-04
| Posted on Friday, August 12, 2005 - 03:20 pm: |
One of the problems I've run into with new tubes is the market for vacuum tubes is still dominated by the musical instrument business. This is especially true in the more popular tube numbers where EL34's, 6L6's, 12AX7's and so forth are used in guitar amplifiers. What the consumer audio market wants from a tube is very different from what the musician wants. Where a consumer will dispose of a tube as distortions rise and the tube is considered worn out, the musician will consider that same tube just getting broken in. The way a tube distorts when overdriven is a consideration for the musician they will seek out. That a tube distorts at all is unpleasant for the "audiophile" to consider. The first set of replacement tubes I purchased back in the early 1980's were from Groove Tube. Their business was predominantly geared to musicicans as the home audio market hadn't swung back to tubes at all from the 1970's. The output tubes I purchased were graded "1" through "10" to indicate their "softness" or "hardness" which indicated how prone to break up the tube was as it reached its limits. The softer the tube the "sweeter" the distortion product and the longer it took to tip into distortion. The harder the tube, the more hard edged distortion the tube produced and, like a transistor amplifier, the sooner it went into clipping. The closer the tube grading got to 10, the more it supposedly duplicated the sound of a solid state amplifier. When shopping for tubes, whether input, driver, rectifier or output tubes, it is best to inquire what the characteristics of the tubes are before you pay your money. A simple question as to where will the tube work best could be important.
Dallas,
TX
Post Number: 5044 Registered: May-04
| Posted on Saturday, August 13, 2005 - 12:11 pm: |
I will paste this here from another thread since it is relevant to this thread also: As long as you are staying with the same type of tube (12AX7 to 12AX7) you can replace any rectifier, input or driver tube without any adjustment to the amplifier, pre amplifier, tuner, CD, etc. The operational characteristics for small signal triodes are established and do not vary enough from manufacturer to manufacturer. You will, however, find a noticeable difference in sound quality among different manufacturer's tubes and even within a group of similar tubes. One 12AX7, while designed to the same overall specs as every other 12AX7 may be designated for low noise, low microphonics, military use or other qualities. You will find letter or number dsignations behind the 12AX7 type to differentiate these special purpose tubes. 12AX7 is a designation given to a tube manufactured in the US or meant for use in the US. Other countries will make similar tubes that swap out with the 12AX7 but have different letter/number designations. (http://www.hktubeaudio.homestead.com/files/tubecode.html) In small signal tubes, these can be interchanged with no problems (typically). When you get to large signal output tubes, you need to be more careful about what goes where. While you can generally swap a KT88 for a 6550, all output tubes will run at different bias levels. Bias can be thought of as the voltage or current through one section of the tube's elements that attracts the oppositely polarized electrons to flow from another element thus affecting gain. Read the last week's worth of entries in Tube Talk for more on bias. The subject of tubes covers way too much territory to give definitive answers too many times. Read up a bit on tubes and you'll get a better idea of what to expect. http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm http://www.vintagelectron.com/ http://www.lh-electric.4t.com/tutorials.htm http://www.tpub.com/content/neets/14178/ http://www.vacuumtube.com/tubes.htm http://hometheater.about.com/od/vacuumtubeaudio/ http://www.tubedepot.com/ http://www.tubedepot.com/whisbipo.html http://www.worldtubeaudio.com/ If you cannot find the information you desire somewhere on the world tube depot site, it probably isn't there to be found.
Atlanta,
GA
Post Number: 944 Registered: Mar-05
| Posted on Saturday, August 13, 2005 - 04:10 pm: |
Wealth of info as always Jan , thank you. |
Dallas,
TX
Post Number: 5086 Registered: May-04
| Posted on Monday, August 15, 2005 - 02:10 pm: |
j.c. - Consider yourself a rich man: Tube (Valve) Amplifier Manufacturers Supratech Triode (beautiful SET amps from Australia) Wavelength Audio (SET amplifiers) Moondog Audio (SET amplifiers and horn speakers, Ron Welborne) Aprilsound (SET amplifiers) Bottlehead (parallel feed amplifiers) David Berning (zero output transformer ZOTL triode amps including the new incredible microZOTL) Decware Zen tube amp Moth Audio (SET amplifiers, high efficiency speakers) Vacuum State Electronics (Allen Wright) high end single ended and balanced kits, cables, and more SAS Audio Labs Tube (Valve) Amplifier Design The Joelist (Sound Practices mailing list) website by Tim Reese Joelist file server Steve Bench's page (tube amp designer and experimenter extraordinaire, lots of information) Duncan's Amp Pages (lots of info including tube database) Bob Danielak's Darling amplifiers using 1626 output tube Audio Amateur (Glass Audio magazine, Audio Electronics magazine) Svetlana tubes and circuits Tube CAD Journal, online tube design e-zine Software for Tube Audio Glass-Ware tube audio design software including Free Curves software Duncan's Amps software including the amazing Power Supply designer ! (free) http://melhuish.org/audio/links.html
Atlanta,
GA
Post Number: 956 Registered: Mar-05
| Posted on Monday, August 15, 2005 - 07:11 pm: |
Silver Member Username: Diablo
Fylde Coast, England
Post Number: 206 Registered: Dec-04
| Posted on Monday, August 15, 2005 - 10:20 pm: |
jc Since you are originally from England, shouldn't that be V A L V E S ! ??
Regards, diablo
London U.K.
Post Number: 3643 Registered: Dec-03
| Posted on Monday, August 15, 2005 - 11:33 pm: |
diablo, I told 'em "thermionic valve" made sense, and "vacuum tube" did not, imho, early on this thread. But let us not fight, again, a war of words! "Tubes" is now international English, we have to agree. Get your Quad II monoblocs running, and we can start to take sides on Quad vs McIntosh. What a pointless civil war that would be (smiley). |
Post Number: 207 Registered: Dec-04
| Posted on Tuesday, August 16, 2005 - 12:47 am: |
Surely, a 'vacuum tube' is one of those bendy things that get attached to a Hoover? ... oh, never mind. I've been doing some more investigations and a little cable making. Will be seeing if the monoblock which did work, still does. Maybe tomorrow. This is to assess whether or not I like the sound before going any further. Been looking at prices of Quad IIs on Ebay and elsewhere. Seems like £200 to £300 each for reasonably decent ones on Ebay. Same for some which seem fairly poor. It tends to be £500 from specialist dealers. They are not as cheap as I thought, but may be still be worthwhile - a lot cheaper than the new versions. Their seems to be a fair amount of interest in them from all over the world, mainly Japan. I suppose that isn't too surprising - they like their valve stuff over there. I might put up a web page, with details of what I do, if I decide to go on with the project. Not for any altruistic motive of helping others - I'm not nearly nice enough to do that - it will help to force myself to document what I'm doing for my own future reference. Regards, diablo p.s. McIntosh are rubbish!!! |
London U.K.
Post Number: 3647 Registered: Dec-03
| Posted on Tuesday, August 16, 2005 - 01:09 am: |
Yeah, but they keep the rain out. "....one of those bendy things that get attached to a Hoover? " That's what I said! Or "vacuum cleaner", as they are more correctly described.... Yes, keep up the good work! |
Dallas,
TX
Post Number: 5091 Registered: May-04
| Posted on Wednesday, August 17, 2005 - 10:22 am: |
diablo - Send me all your rubbish. |
Atlanta,
GA
Post Number: 958 Registered: Mar-05
| Posted on Thursday, August 18, 2005 - 07:40 am: |
Actually, they shouldn't be called vacuum anything. 'Cause they don't suck! Jan, sometimes I think your a flash git and other times I think you've just gone and joined the barmey army! |
New member Username: Vm8444
Post Number: 1 Registered: Aug-05
| Posted on Saturday, August 20, 2005 - 01:23 am: |
hi there,,I just recieved my primaluna one today,,anybody try tube rolling with this amp,,I heard this amp with my maggies 1.6 in the store and I was sold,, I use to run a 25 watt audio innovations tube amp,,and that was pretty loud for me ,,but I wanted a little more,, so taz from a previous post no worries here ,,the prima one at 35 watts will drive the mmg's really well..I KNOW BECUSE i TRIED ,,to all you naysayers out there na na na na na |
Atlanta,
GA
Post Number: 969 Registered: Mar-05
| Posted on Saturday, August 20, 2005 - 12:15 pm: |
Wow, what an insightful post vince. |
Warren,
MICHIGAN
Post Number: 2629 Registered: Dec-03
| Posted on Sunday, August 21, 2005 - 01:35 am: |
For anyone interested, I picked up a pair of unique speakers today. Yah I know realistic speakers must be garb right, well that's what I figured but there design and the price made me grab em ($3 for the pair used of'course) Well they are a larger then normal 2-way (8" woof 3" tweet) with a 10" passive radiator and they are also an attempt at being time aligned as the top portion of the cabinet where the tweeter is mounted is set back about 2". After taking them apart to inspect, a very intersting xover reveals it'self, the woofer is run full range (no xover) and all the tweet has is 1 cap! Now if that isn't a pretty minumal xover then I don't know what is. After checking them out on the garage setup I see why they have no xover on the woofer as there is no highs comming from that unit and the mids that are there sound great. My guess is the 8" driver rolls off naturaly to a point then the tweet takes over. From the limited testing so far this speaker system has some potential and I am curious to try these on the 300B with some jazz and acoustical music (as I do not see them being a loud/big rock speaker). The extremely limited info I have found for these speakers so far (Optimus-40) Power Input: 75 Watts Max Frequency Response: 40 Hz to 20,000 Hz Sensitivity: 89 dB @ 1 W/m Wish I could get a phase and impedance chart for them to really try and determine if weather they fit the mold of a "tube friendly speaker" but the simple xover and decent sensitivity have me intrigued though, keep yu posted.
Gold Member Username: Joe_c
Atlanta,
GA
Post Number: 1026 Registered: Mar-05
| Posted on Wednesday, August 24, 2005 - 09:18 pm: |
Will give you guys a report on the difference between Sovtek 6550 and Electro Harmonix KT88's when I get them tomorrow. The Sov's are decent but seem to push the midrange to uncomfortable levels when the amp is pushed. Looking forward to seeing how the E H's work. |
Warren,
MICHIGAN
Post Number: 2659 Registered: Dec-03
| Posted on Wednesday, August 24, 2005 - 09:37 pm: |
joseph your a regular tubaholic. I like it! |
Dallas,
TX
Post Number: 5310 Registered: May-04
| Posted on Wednesday, August 24, 2005 - 10:16 pm: |
j.c. - I appreciate the information and your enthusiasm; but you know the sound of a tube is the sound of that tube within that amplifier's circuit; right? |
London U.K.
Post Number: 3729 Registered: Dec-03
| Posted on Thursday, August 25, 2005 - 01:13 am: |
vince, Going back a few posts, "Two Cents" did some tube replacements with a Prologue Two, I think. Glad your Prologue One works with MG 1.6. "Art", on another thread maintains Magnepan speakers need lots of power. I find the 40W of the PL2 is more than adequate for my speakers which notionally require 50W minimum. I understand there are those who prefer the EL34 output of the PL1, and the power rating difference between the two amps is a mere 5 W. |
Atlanta,
GA
Post Number: 1031 Registered: Mar-05
| Posted on Thursday, August 25, 2005 - 07:44 am: |
I do Jan, and I see no other way to find out whether that sound is different besides buying up all the tubes in the known universe and trying them. (puts little finger to side of lip like Dr. Evil) P.S. Jan I already have the Sovteks, that's why I made that call. |
Atlanta,
GA
Post Number: 1056 Registered: Mar-05
| Posted on Friday, August 26, 2005 - 11:57 pm: |
I love the smoothness of these new E H KT88's vs. the Sovteks. They seem to be more consistent throughout the volume range than the Sov's. And I realized that it was not the 12ax7's that were breaking up at high levels. All the 12ax7's I have accumulated over the past couple of weeks sound really good. The NOS ones seem to have a slight edge with the Electro hr's coming in a close second. All in all, wonderful sound. And hey, how can you beat $600 for the amp! |
Gold Member Username: Thx_3417
Post Number: 1187 Registered: May-05
| Posted on Saturday, August 27, 2005 - 12:17 am: |
-CRYBABY- Bed-time..... Rock-a-bye baby, in the tree top When the wind blows, the cradle will rock When the bough breaks, the cradle will fall And down will come baby, cradle and all
Dallas,
TX
Post Number: 5362 Registered: May-04
| Posted on Saturday, August 27, 2005 - 12:37 am: |
Hey, Ashley & j.c. - Find a thread of your own. This crap is getting old. |
Atlanta,
GA
Post Number: 1058 Registered: Mar-05
| Posted on Saturday, August 27, 2005 - 12:58 pm: |
Jan , I have not ventured outside of the specific threads with this idiot, I cannot help it if he wants to ruin every thread. |
Atlanta,
GA
Post Number: 1060 Registered: Mar-05
| Posted on Saturday, August 27, 2005 - 01:03 pm: |
Anyway, I think I have changed my mind on the pre tubes, even though the Electo's do not have the lower end extension that the NOS USA ones do, I prefer the sound and depth (do not know how to describe what I am hearing short of calling it depth. |
| Posted on Tuesday, September 27, 2005 - 09:07 am: |
Thanks for a most interesting thread, Rick. You are missed. |
Dallas,
TX
Post Number: 5859 Registered: May-04
| Posted on Tuesday, September 27, 2005 - 08:38 pm: |
http://hometheater.about.com/od/vacuumtubeaudio/a/vacuumtubeaudio.htm?nl=1 |
Silver Member Username: Dakulis
Spokane,
Washington
United States
Post Number: 552 Registered: May-05
| Posted on Wednesday, September 28, 2005 - 08:50 pm: |
It appears that this thread may be dying. But, speaking of truths, here's one I just discovered. Never forget who your friends are. As many of you know, I'm heading off to SLC for several reasons, however, included in the trip is the opportunity to go into a real audio store and listen to real audio equipment. (You guys know that I've proclaimed Spokane as the audio desert.) Anyway, I called a long lost buddy today that I had mentioned before. He's an electronic wiz and he buys old tube amps, fixes them up and sells them all over, usually to Asia. (Yes Jan, he has a number of Macs in the house, a couple of old Fisher models and some old H&K.) I told him about my difficulty with the whole HT and combined music system. (Now, I know you guys have never heard this before. LOL. He said, "Don't spend any money in SLC on that crap. You'll never be able to get decent music out of a multi-channel amp and pre/pro.") Then, I told him the story of my old Luxman tube amp and AL Stonehenge IIs. He said, "can't do anything about the Luxman you tossed, even though you weren't too bright on that one, but I repair ALs, Klipschorns and EVs all the time." He told me to bring 'em over, he'll buy the parts and do the repair word for nada and I have to do is reimburse him for the parts. Then, it gets better. He says that after he fixes the ALs up, he'll pair them up with one of his tube amps and if I like what I hear, he'll set me up very reasonably and I won't be spending a bunch of money. (Of course, he says I still have to fight the WAF over placement of the humungous speakers and 2 channel system somewhere in the house.) And, he says if I'm not happy with the end result, I don't have to buy the amp, he'll buy the speakers off me at a reasonable price and sell 'em for more than enough to make back his labor and he'll sell the amp to someone else at a huge profit. Truth=honesty, no? PRETTY COOL and I'll report back if this goes even half that well.
Dallas,
TX
Post Number: 5873 Registered: May-04
| Posted on Wednesday, September 28, 2005 - 09:30 pm: |
Good luck, Dak. |
Silver Member Username: Timn8ter
Seattle,
WA
Post Number: 548 Registered: Dec-03
| Posted on Wednesday, September 28, 2005 - 09:58 pm: |
Super duper! |
London U.K.
Post Number: 3775 Registered: Dec-03
| Posted on Thursday, September 29, 2005 - 01:27 pm: |
Yep. Good luck! "SLC" equals "Salt Lake City"....? "AL"..? |
Dallas,
TX
Post Number: 5890 Registered: May-04
| Posted on Thursday, September 29, 2005 - 01:54 pm: |
AL = big box! |
Spokane,
Washington
United States
Post Number: 553 Registered: May-05
| Posted on Thursday, September 29, 2005 - 04:38 pm: |
AL = Altec Lansing, Stonehenge IIs. These puppies aren't as big as Peter's Klipschs but they're pretty honkin' big, just about 2/3s the width of the AL Studio Standards, about 40" x 24" x 24" and probably 60-75 lbs. a piece. They come in solid oak cabinets, have 12" woofers and a mid and a tweeter but no horns, which the Studio Standards had. Anyway, in their day, they sounded very good. |
Spokane,
Washington
United States
Post Number: 554 Registered: May-05
| Posted on Thursday, September 29, 2005 - 04:46 pm: |
BTW Jan, John A, JC, Diablo and others, WOW, incredible information on this thread. If I head down this road, I'll need some serious additional education on tubes, it's been a long time since I was there. But, I'll read first and ask later, so as not to annoy too much. Thanks again all, Dave |
Dallas,
TX
Post Number: 5892 Registered: May-04
| Posted on Thursday, September 29, 2005 - 05:26 pm: |
A lot of what you need to know has been covered on this thread. Any questions you have, just ask. And, of course, tubes sound good with newer, smaller speakers also.
New member Username: Darkmusic
Dover,
Delaware
Usa
Post Number: 6 Registered: Apr-05
| Posted on Friday, September 30, 2005 - 01:09 pm: |
Jan, Kegger, and Rick (alphabetical order): After months of reading and re-reading "old dogs" and "tube talk," doing research, and listening to amplifiers and a lot of music, I ordered my new integrated -- a Jolida 707 (my MA6100 will soon become part of our A/V unit). I have you three (specifically) to thank -- for advice, cautions, and anxiety (joking). Since Jolida seems to be a bit "backed up," it will probably be two weeks before the unit arrives. I'll let you all know what happens. I have learned a lot from all who have contributed to this thread. Thanks Pardoners! |
Dallas,
TX
Post Number: 5904 Registered: May-04
| Posted on Friday, September 30, 2005 - 01:27 pm: |
That's why we hand out silver bullets, RAC. What do you teach? |
London U.K.
Post Number: 3776 Registered: Dec-03
| Posted on Saturday, October 01, 2005 - 03:38 pm: |
Cracking thread, chaps. |
Dover,
Delaware
Usa
Post Number: 7 Registered: Apr-05
| Posted on Monday, October 03, 2005 - 11:18 am: |
"What do you teach?" Students... but occasionally a small rodent wanders into the classroom (sorry, it's my standard response). I teach college composition, world mythology, and American literature (1492-1980's). |
Dallas,
TX
Post Number: 5952 Registered: May-04
| Posted on Monday, October 03, 2005 - 12:45 pm: |
So whatever happened to J.D. Salinger? |
| Posted on Tuesday, October 04, 2005 - 11:23 pm: |
Tube nuts look here: http://forum.ecoustics.com/bbs/messages/1/165993.html
Dover,
Delaware
Usa
Post Number: 8 Registered: Apr-05
| Posted on Wednesday, October 05, 2005 - 07:38 am: |
"So whatever happened to J.D. Salinger?" I believe he is preparing for a poker game with Ginsberg, Kesey, Kerouac, and Thompson. "Eventually, everyone has to cash in his chips." --I do not know who said it, but it seems about right.
Dover,
Delaware
Usa
Post Number: 9 Registered: Apr-05
| Posted on Thursday, October 13, 2005 - 11:36 am: |
Greetings from Dover! The J707 arrived last Friday. I have been listening to it quite as bit. When I first connected it up and began listening I was disappointed – my bass had disappeared. So I thought, well, this is not what I heard in the shops I visited, but maybe my Tannoy speakers have something to do with the problem. The bass sounded muted and way way back in the soundstage. I tried switching speaker taps from 8 to 4 ohms. Some bass appeared, but not enough (or as much as I heard at the shops or with my MA6100). I switched back to 8 ohm and attempted to live with the sound. The tubes seemed to opened up while I was listening to Bonnie Raitt (a nice experience, even with muted bass even at an elevated volume). I was one unhappy camper until Wednesday morning when it occurred to me to disconnect the tube buffer (xboxv3) I was running between the cd player (xray) and the 707. Once I connected the cd player directly into the 707 (Wednesday afternoon) I smiled – the bass had returned (though the highs and midrange are not as “warm” as with the buffer connected). As far as I can tell, the tube buffer works well with a solid state amplifier (like the MA6100) – it warms up the music. With a tube unit (like the 707) the buffer seems to add a “veil” (or filter) to the music – I almost enjoyed the highs and the midrange because the sound was so different, but oh did I miss the bass on my reference cds (Mitchell’s Don Juan’s Reckless Daughter – bass by Jaco – and Ray Hubbard’s Growl). In fact, I discovered that I was giving myself a headache as I listened for the bass and not the music. Of course another explanation is that I am imagining all of these differences. Tonight I will try the 4 ohm taps again (this time without the buffer). And now a question (from a newbie): If tubes are used in both preamp and amp (or in an integrated amp), why should tubes be used in a tuner, cd player, or phono preamp? The “fast” answer is that “it sounds good to the listener,” but aside from that response, what are the “electronic” benefits? Let me ask the question another way – if there are tubes in the preamp (for a nice warm and open sound), what sonic benefits are there to using tubes in the other devices?
Dallas,
TX
Post Number: 6135 Registered: May-04
| Posted on Thursday, October 13, 2005 - 03:55 pm: |
Ideally tubes should not sound like "tubes". That some manufacturers promote their products as ways to introduce "tube sound" into your system is a disappointment to those of us who enjoy the musical values of tubes and are not looking to add "warmth" or remove "CD sound" from our systems. However, if that is the sort of product that is introduced into the system, a little can go a long way. Too much can make the system just as unlistenable as too much of any one quality in an audio system. Let the system work for a few days and then you might want to consider tweaking your system around the sound of the new amplifier. I don't recommend being obssesive about the affair but tube porducts can be tailored to your tastes with the use of different tubes. The advantage to using tubes, particularly in a tuner, would be the overall linearity of a tube used as a gain device or a tuning device. One of the most well respected tuners of the last half century is still the tube based Marantz 10B. The tube based McIntosh and Fisher tuners are sought after at high prices as are many other classic tube based designs. The simplicity of tube based circuits generally is a good enough reason to consider tubes against the more complex solid state devices. Everything has its place in audio and everything has trade offs which means there is no right or wrong when judged against how the device is used. Transistors have their place and if tubes are used just to have the system not sound like solid state amplification is used, then you can easily get into trouble with tubes or with any other device. |
Dover,
Delaware
Usa
Post Number: 10 Registered: Apr-05
| Posted on Friday, October 14, 2005 - 07:34 am: |
Thanks, Jan. Fall break arrives at my institution today -- five days of "peace, love, and music" and two sets of freshman compostion projects to critique! It will take quite a bit of Coltrane and Davis to pull me through! Have a good weekend! |
Dallas,
TX
Post Number: 6138 Registered: May-04
| Posted on Friday, October 14, 2005 - 09:52 am: |
Try some Blossom Dearie. You can't be anything but smiling from the inside after 35 minutes with that lady. |
Silver Member Username: Two_cents
Post Number: 650 Registered: Feb-04
| Posted on Monday, October 17, 2005 - 08:43 pm: |
Argh! I'm sad to report my first bad experience with tubes. One of the stock KT88s on my Primaluna P2 went bad in less than a year. I hear a loud pop every time the amp powers up. After rotating the location of the 4 tubes, I identified the bad one. That'll be $35 down the tube (pun sadly intended). Is the extra hassle and expense worth the tube sound? Helll yeah! John A., how's your P2 holding up? RAC, I don't know about the combination of a tube cd player/tuner with a tube amp, but I can certainly recommend a turntable with a tube amp. There's something about listening to vinyl through a tube amp that just makes my ears want wrap themselves around the music and give it a tender hug. |
London U.K.
Post Number: 3794 Registered: Dec-03
| Posted on Tuesday, October 18, 2005 - 02:56 am: |
"John A., how's your P2 holding up?" Excellent, Two cents. I understand I shall have to replace output tubes eventually. Mine works perfectly, I think is nicely run in, and shows not a single glitch of the demo unit, all down to a faulty input selector, I think. No problems at all. Still recommended. Good to hear from you! |
| Posted on Tuesday, October 18, 2005 - 12:28 pm: |
Help, I am trying to install a rockford 100 amp with 2 rockford 10" punches. but the problem I'm having is that my speakers in the car are now getting to much watts & not getting much to the subs is there a simple fix to this. I use to be able to turn the volume up to 35 and now if I go to 15 I fill I blow them. But if the speakers are disconnected then I can turn it up and get a little hit but its distorted. Please add any input at all. I need help bad!!! |
Dallas,
TX
Post Number: 6210 Registered: May-04
| Posted on Tuesday, October 18, 2005 - 12:35 pm: |
You certainly do! And you are not going to find it here. This portion of the forum is clearly marked "Home Audio". |
| Posted on Tuesday, October 18, 2005 - 01:22 pm: |
Sorry, Where do you suggest I go. |
| Posted on Tuesday, October 18, 2005 - 01:59 pm: |
Uhh car audio! |
Post Number: 651 Registered: Feb-04
| Posted on Tuesday, October 18, 2005 - 07:46 pm: |
Were tube amps ever available in cars? I know that turntables were an option on some cars back in the golden days of stereo. A car tube amp isn't nearly as wacky. John A.- Glad to hear your P2 is working excellently. Now you just need to retrieve your turntable |
Dallas,
TX
Post Number: 6215 Registered: May-04
| Posted on Tuesday, October 18, 2005 - 11:55 pm: |
Tube based radios were popular items in cars from the 1930's through the 1950's. Kegger posted a link to a contemporary tube based unit from Panasonic. I think that was done on Old Dogs.
Post Number: 653 Registered: Feb-04
| Posted on Wednesday, October 19, 2005 - 03:22 am: |
Jan, I figured you knew the answer. Thanks. Anyone heard from Kegger? |
